View Full Version : 12in Brakes on 1991 Sedan DeVille???
N0DIH
08-18-04, 01:51 PM
http://www.acdelco.com/html/pi_plugs_irid_main.htm
Thanks for the link! I found something interesting here.
The 4th Generation F Car uses the same rotors as our beloved C and H Body.
So, the possibility of larger aftermarket brakes just became a possibiliy.
You can get bigger rotors, so all you need to do is figure out how to extend the caliper out to fit the larger rotor.
Hmmmmm, anyone have any thoughts, warped or not?
Tom
90devilleguy
08-20-04, 02:50 AM
Tom
just get some cross drilled or slotted rotors for the car i did on my caddy and the car has unbelieve stopping power.i'll find the website i bought them from.it was like $140 for the set in the front. pads to from the same company are very good,ceramic i think.
DeVillish
08-23-04, 08:26 PM
is 4th gen like 93 and up right? if they use the same disks you could use the big brake kits for f-bodies and have a bracket for the caps made in a shop. I'am gona look into that when i get home before i get sent to japan.
