: What year N* engine block will work for 2000 deville
jaguarstype24
03-08-10, 12:47 PM
and what special tools do you need to remove the heads? Thanks for any help
Ranger
03-08-10, 06:26 PM
I am not sure what 2000+ blocks will work, but I do know you can't use a pre 2000 block.
Once the engine is out, just conventional tools are all that's needed.
tateos
03-09-10, 12:40 PM
Well, Ranger, it depends on what you consider special tools.
He will need a 10mm male hex driver for the head bolts. A torque wrench. An angle gauge to tighten the head bolts (not if you use Jake's studs) and some other bolts correctly. He will need a very good impact wrench or a very long breaker bar to break loose the crankshaft damper bolt. A power steering pulley puller and installer for the water pump drive. There is a special tool used to lock the flywheel in place while timing the engine, but as I recall, I used a bolt and a pair of vice grips. I used a speed square on the cylinder heads to make sure the marks were at 90 degrees/12:00. If he is going to replace the rear main seal, a very special tool is required - I purchased mine directly form SPX for almost $300, although I have since seen them on e-bay for ~$25 used.
Ranger
03-09-10, 01:19 PM
Very true, but I guess that with the exception of a power steering pulley puller and installer for the water pump drive and the flywheel locker, I consider most of that stuff basic if you are doing a job like this.
tateos
03-09-10, 09:10 PM
I'm nit arguing with you, Ranger, but who knows what someone else considers basic.
BTW, I forgot to mention I purchased this harmonic balancer installer
http://www.kikaenterprises.com/images/CJ139p.jpg
Others have purchased a longer bolt and used it and greased up washers, but the installer was so slick, with the ball bearings and all, it made it a real pleasure. I think I paid around $20 for the tool on e-bay, new, and delivered
