: 2009 TSB list
LITTLEELVISDAN
03-08-10, 11:41 AM
This is what I have so far.
Remote keyless entry - Transmitter inop --- TSB -08-08-52-005
Tire press light on --- TSB 09-03-16-001
Eng no crank - batt discharge/parasitic drain ----- TSB 09-06-03-002
front / rear door adjustment --- TSB 09-08-64-010
outside rearview mirror distortion --- TSB 09-08-64-011
body mounted weather strip replacement --- TSB 09-08-64-012
Rear parking assist inop --- TSB 09-08-127-001
Front suspension clunk/squeek/rattle/popping ---- TSB 09-03-08-006
front or RR door window binds/slow/noisy/inop --- TSB 09-08-64-015
front windshield wiper function --- TSB 09-08-43-002
Hope this helps
LITTLEELVISDAN
03-22-10, 08:40 AM
Automotive Recall and Technical Service Bulletin Titles for 2009 Cadillac Truck Escalade AWD V8-6.2L.
TSB Number & Issue Date TSB Title
09269 OCT 09 Campaign - Heater Hose Coolant Leak
09109A JUN 09 Campaign - Automatic Wipers Inoperative/Work Manually
08386 APR 09 Campaign - Missing Mercury Disposal Notice Label
08259A NOV 08 Campaign - Inoperative OnStar(R) System
08313 OCT 08 Campaign - XM Satellite(R) Radio Receiver Replacement
09-08-61-001A OCT 09 Body - Tubular Assist Step Service Parts Cpomponents
06-08-64-001B OCT 09 Body - Side Window Chipping Information
05-03-08-002C OCT 09 Suspension - Shock Absorber/Strut Leakage Information
08-07-30-006A OCT 09 A/T - Valve Body Reconditioning Info.
08-08-67-016C OCT 09 Body - Roof Panel Flutters/Rattles When Closing Doors
09-08-55-001 OCT 09 Collision Avoidance - False Side Blind Zone System Mssg
09-06-03-002D OCT 09 Electrical - Engine No Crank/No Start/Discharged Battery
06-08-50-009D OCT 09 Restraints - Passenger Presence System Information
06-00-89-031A OCT 09 Engine, A/T - Identification Information
08-08-48-003B SEP 09 Body - Tap, Click, or Tick Noise At Windshield Area.
06-08-111-004B SEP 09 06-08-111-004B - BULLETIN CANCELLATION NOTIFICATION
09-08-44-018 SEP 09 Audio/Electrical - No Crank/Start/Dead Battery/No Audio
05-06-01-034I SEP 09 Engine - Oil Leaks At Rear Of Cylinder Block
09-08-44-002C SEP 09 Navigation Radio - Blank Screen/Screen Freezes
09-08-48-006 SEP 09 Body - Stain/Film On Windshield Glass Perimeter
09-03-10-008A SEP 09 Wheels/Tires - Module Programming For 20/22 Inch Wheels
08-08-52-001E SEP 09 Keyless Entry - Intermittent,/Inoperative Remote
07-03-08-009A SEP 09 Suspension - Cast Iron/Aluminium Control Arm Ball Joint
02-07-30-052F SEP 09 A/T - Fluid Oil Cooler Flush
09-06-03-004B SEP 09 Electrical - MIL ON/DTCs Set By Various Control Modules
09-08-50-014 AUG 09 Interior - Seat Memory Inopertive After Air Bag Deploys
08-07-30-021C AUG 09 Electrical - Multiple DTCs/Electrical Malfunction
09-03-08-005A AUG 09 09-03-08-005 - BULLETIN CANCELLATION NOTIFICATION
09-08-49-014 AUG 09 Interior - Center Console Lid Service Information
04-06-04-047I AUG 09 Fuel System - 'TOP TIER' Detergent Gasoline Information
07-08-47-004B AUG 09 Body Control Module - Ground Information
07-03-10-008B AUG 09 Tires - Slight/Mild Edge Feathering Information
09-08-127-001B AUG 09 09-08-127-001 - END OF INFORMATION NEED
08-08-46-003C AUG 09 OnStar(R) - Destination Download Incomplete/Intermittent
06-02-32-013B AUG 09 Steering - Power Steering Pump Replacement Tips
06-08-50-006C AUG 09 Interior - 3rd Row Seat Hard To Install/Remove
03-03-10-007E AUG 09 Wheels/Tires - OE Tire/Wheel Characteristics
06-08-44-035C AUG 09 Entertainment System - DVD Screen Off After Ign. Cycle
08-08-44-021C AUG 09 Navigation Radio - Won't Accept/Play/Eject CD's
09-01-38-004 JUL 09 A/C - A/C Indicator Or Recirculation Indicator Flashing
08-08-61-005A JUL 09 Body - Front/Rear Fender Liners Warped/Wavy
09-08-49-013 JUL 09 Body - Removal and Installation Of Roof Console
09-03-08-006A JUL 09 Suspension - Front End Clunk/Squeak/Rattle/Pop/Creak
07-08-44-001D JUL 09 Audio System - Antenna Mast ID/Application
99-08-64-016C JUL 09 Body - Maintaining Exterior Weatherstrip Appearance
03-07-29-004F JUL 09 M/T - Operating Characteristics
08-06-01-008A JUL 09 Engine - Drive Belt Misalignment Diagnostics
07-06-01-016B JUL 09 Engine - Noise/Damage Oil Filter Application Importance
08-03-10-004A JUL 09 Wheels/Tires - Accessory Wheel & Tire Information
09-08-64-010A JUL 09 09-08-64-010A - END OF NEED FOR INFORMATION
07-02-32-002H JUL 09 Steering - Fluid Leaks From The Steering Gear/Rack
09-03-16-001A JUL 09 Tire Monitor System - End Of Need For Information
09-08-50-011 JUN 09 Body - Sticking/Binding Door Mounted Seat Switches
09-09-41-005 JUN 09 Restraints - Air Bag Readiness Light On.
06-02-35-003C JUN 09 Steering - Squeak When Turning/High Steering Effort
09-08-50-006A JUN 09 Interior, A/C - Bulletin No Longer Needed
08-08-52-005C JUN 09 Keyless Entry - End Of Need For Information
05-08-51-008C JUN 09 Body - Bumps or Rust Colored Spots in Paint
07-07-30-010B JUN 09 A/T Controls - Snapshot Data Upload Information
09-06-04-028 JUN 09 Emission - MIL ON/DTC's P0442/P0446/P0455/P0449
08-06-03-008A JUN 09 Battery - Intermittent Drain Diagnostic Tips
08-07-30-042B JUN 09 08-07-30-042B - END OF NEED FOR INFORMATION
09-08-64-024 JUN 09 Power Liftgate - Liftgate Open/Rear Access Open
07-09-40-002A JUN 09 Restraints - Seat Belt Latch Stop Button Availability
09-08-64-023 JUN 09 Body - Outside Door Handle Pulls Out of Base
09-08-110-013 JUN 09 Interior - Sun Visor Fails to Stay In Up Position
03-08-48-006F MAY 09 A/C - Window Defroster Contact/Tab Repair Information
08-08-127-001A MAY 09 Park Assist System - Inoperative/Lamp ON/DTC's Set
06-00-89-029E MAY 09 Interior - Interior Surfaces Cleaning
07-09-40-001A MAY 09 Restraints/Interior - Front Seat Belt Twisted
06-08-44-015B MAY 09 Audio System - Noise When Using Portable Playback Unit
02-08-44-007D MAY 09 OnStar(R) - Negative Impact of Cloth/Vinyl Roofs
05-03-10-003D MAY 09 Wheels/Tires - Low Tire Pressure
01-08-42-001G MAY 09 Lighting - Exterior Lamp Condensation Guidelines
09-03-16-002 MAY 09 Tire Pressure Monitor - Service Tips
09-03-10-007 MAY 09 Wheels - Center Cap Loose, Retention Wire/Ring Missing
09-05-22-003 APR 09 Brakes - Feel Grabby or Touchy DTC C012E Reprogramming
09-05-22-003 APR 09 Brakes - Grabby/Touchy Or DTC C012E Stored
07-08-47-005B APR 09 Body - Power Liftgate Opens Part Way Then Reverses
09-04-19-001 APR 09 Drivetrain - Whine or Click Type Noises from Front Axle
09-06-04-021A APR 09 Engine Controls - MIL ON/DTC P0461 Set
09-08-66-007 APR 09 Liftgate - Close Actuator Motor Change
06-08-64-027G APR 09 Mirrors - Driver's Door Mirror Glass Shakes/Flutters
09-08-64-015 APR 09 Body - Front or Rear Side Door Window Multiple Problems
09-06-04-024 APR 09 Engine Controls - MIL ON/Multiple DTC's
09-08-63-004 APR 09 Body - High Pitched Squeak Noise At Left/Right A-Pillar
07-08-49-020C APR 09 Instruments - IPC Odometer Programming Reference Guide
03-06-04-030G APR 09 Fuel System - Driveability Issues/MIL/Multiple DTC's
09-07-30-004A APR 09 A/T - Shift Flare/Harsh 2-3 Shifting
08-07-30-024A APR 09 08-07-30-024 - END OF INFORMATION NEED
07-06-05-001F APR 09 Exhaust System - Buzzing/Snapping/Popping Noises
07-07-30-006A APR 09 A/T - Control Valve/Solenoid Cleaning Procedures
08-08-50-001A APR 09 Interior - Front Seat Cushion Cover Becomes Detached
09-08-47-001 APR 09 Body Controls - Unable to Reprogram Body Control Module
09-08-64-012 APR 09 Body - Front/Rear Door Wind Noise/Water Leaks
09-08-64-011 APR 09 Instruments - L/H Door Mirror Glass Distorted
08-02-35-004A MAR 09 Interior - Steering Wheel Cover Warped/Paint Peeling
08-03-10-005A MAR 09 Wheels/Tires - Chrome/Steel Valve Stem Cap Precautions
00-05-22-002L MAR 09 Brakes- Disc Brake Warranty Service And Procedures
07-03-16-004B MAR 09 Tire Monitor System - Overview/FAQ/Diagnostics
04-03-10-001E MAR 09 Wheels/Tires - Tire Puncture Repair Procedures
09-08-43-001 MAR 09 Electrical - Various Electrical Malfunction/Systems Inop
08-08-44-031A MAR 09 Audio System - No Audio/Door Chime/Turn Signal Indicator
09-08-48-002A MAR 09 Body - Marks/Stains on Windshield When Wet
09-03-08-001A MAR 09 Suspension - Revised Front Lower Ball Joint Nut Torque
08-08-44-010F MAR 09 Navigation Radio - Diagnostic Tips
08-03-08-003A MAR 09 Drivetrain - Gen II Vs. Gen III Wheel Hub Changes
09-08-64-003 FEB 09 Instruments - Outside Mirror Adjustment Information
09-09-40-001 FEB 09 Restraints - Seat Belt Warning Lamp On/Buckling Issues
06-00-89-051C FEB 09 Locks - Key Code Security Rules And Information
02-08-98-002C FEB 09 Body - Hem Flange Rust Repair Information
08-09-41-009A FEB 09 Restraints - Information on DTC B0081 5A
09-06-05-001 JAN 09 Exhaust System - Sulfur Odor Explanation
01-07-30-036H JAN 09 A/T Control - DTC P0756 Diagnostic Tips
08-08-45-004A JAN 09 Electrical - Aftermarket Electrical Accessory Precaution
08-03-16-004A JAN 09 Tire Monitor System - Tire Pressure Light Stays ON
07-08-98-001A JAN 09 Body - Non-Approval of Clipping For Collision Repair
00-00-90-002J JAN 09 Tires - Correct Inflation Pressure Information
05-03-10-020B JAN 09 Tire - Use Of Nitrogen Gas In Tires
08-06-04-033C DEC 08 Engine Controls - Aftermarket Calibration Identification
01-06-01-011E DEC 08 Gasoline Engine - Oil Consumption Guidelines
08-08-42-005A DEC 08 Lighting - Headlamp Replacement Guidelines
07-08-50-022A DEC 08 Interior - 2nd Row Seat Rattles/Hard To Latch/Unlatch
08-04-19-006 NOV 08 Drivetrain - L/H Front Axle Removal Tips
07-03-10-013D NOV 08 Wheels/Tires - Vibration While Driving
07-08-50-004A NOV 08 Interior - 3rd Row Seat Squeaking Noises
08-06-03-009A OCT 08 Electrical - Reducing Intermittent Electrical Concerns
08-09-41-010 OCT 08 Restraints - Air Bag Lamp ON/Multiple DTC's Set
06-08-49-014A OCT 08 Interior - Console Ashtray/Cupholder Door Slow to Open
08-08-67-015 OCT 08 Body - Roof Rack Lifting Away From Roof When Used
06-03-10-001F OCT 08 Wheels/Tires - 20/22 Inch Accessory Wheels & Tires
08-08-110-014 OCT 08 A/C - Insufficient Air Flow From 2nd Row Roof Vents
08-08-46-007 OCT 08 OnStar(R) - Stolen Vehicle Reduced Speed Feature
08-07-300-042 SEP 08 A/T - MIL ON/Various DTC's/Poor Driveability
01-07-30-032E SEP 08 A/T - 4T65E Fluid Leaking From A/T Vent
00-00-89-027E SEP 08 Interior - Elimination Of Unwanted Odors
08-08-46-006 SEP 08 Audio System - XM(R) Terrestrial Repeater Changes
06-08-44-012C SEP 08 Navigation System - DVD Navigation Updates Program
08-08-44-021B SEP 08 Navigation Radio Won't Accept/Play/Eject CD's
05-03-10-005D SEP 08 Wheels/Tires - Upsized Wheel/Tire Characteristics
02-08-42-001C SEP 08 Lighting - Headlamp Polycarbonate Lens Damage Prevention
07-03-10-016C AUG 08 Wheels/Tires - Required Label When Changing Wheels/Tires
08-08-44-028 AUG 08 Audio - Inadvertent Steering Wheel Button Activation
08-08-42-004 AUG 08 Lighting - Dome/Reading Lamps Inoperative
08-04-19-004 AUG 08 Drivetrain - Correct Front Axle Vent Hose Routing
08-07-30-039 AUG 08 A/T Controls - Service Fast Learn Adapts Characteristics
08-08-64-013 AUG 08 Body - Door Module/Switch Programming Information
06-08-45-008B AUG 08 Electrical - Trailer Brake Controller Wire Harness
08-08-126-001 AUG 08 Navigation Radio - XM NAV(R) Traffic Coverage Areas
08-08-46-004 AUG 08 OnStar(R) - Aftermarket Device Interference Information
08-08-44-027 AUG 08 Navigation Radio - Weak Or No GPS Signal Information
08-08-44-026 AUG 08 Audio System - Refurbishing Radio Faceplates/Knobs
08-07-30-035 AUG 08 A/T - Water Or Coolant Contamination Information
05-06-04-022E AUG 08 Fuel System - TOP TIER Detergent Gasoline (Canada)
06-08-44-009A AUG 08 Electrical - Various Rear Door Electrical Malfunctions
06-08-44-034C JUL 08 Navigation Radio - Various Noises Explained
07-08-49-014A JUL 08 Parking Assist System - 'Park Assist Off' Message on DIC
02-06-03-008D JUL 08 Charging System - Low Voltage Display/Battery Discharged
07-06-03-009A JUL 08 Charging System - Volt Meter Fluctuation Information
08-06-01-015 JUL 08 Engine - Drive Belt Chirping Noise
08-06-03-007 JUN 08 Electrical - No Start/No Crank/Int Electrical Operations
08-08-64-011 JUN 08 Mirrors - Heated Mirror Defrosting Time
08-07-30-030 JUN 08 A/T - Shift Stabilization/Tow Haul Mode Features
08-08-44-023 JUN 08 Navigation Radio - Adaptation After Radio/Battery R&R
05-00-89-072B JUN 08 Engine/Fuel System - Oil/Fuel Additive Information
07-06-03-002B JUN 08 Battery - Battery Cable Bolts/Clamps/Nuts Inspection
06-08-61-005B JUN 08 Body - Initialization of Articulating Running Boards
07-08-48-004A JUN 08 Instruments - Compass/Temperature Display Information
08-07-30-026 MAY 08 A/T - Slight Vehicle Movement In Park At Start Up
08-03-10-007 MAY 08 Tires - Minimizing Damage to TPM Sensors
01-07-30-010C MAY 08 A/T - Torque Converter Replacement Information
08-03-16-003 MAY 08 Tire Monitor System - TPM Sensor Information
05-06-03-002C APR 08 Battery/Charging System - Electrical Diagnostics Info.
02-06-03-009C APR 08 Electrical - Battery Charging Tips/Recommendations
00-06-01-012C APR 08 Engine - Use of 'Surface Conditioning Disks'
08-08-51-002 MAR 08 Body - TPO Fascia Cleaning Prior to Painting
hcvone
03-22-10, 09:01 AM
I am surprised my 09' even runs with all the TSB. :thumbsup::)
evois
03-22-10, 09:35 AM
the TSB's are for owners who never read the OM and complain to the dealer and now GM has to write a TSB about it.
e.g.
hcvone
03-22-10, 10:09 AM
I know I was just kidding. ;)
evois
03-22-10, 11:18 AM
but, I can't believe that the escalade has so much TSB listed:eek: even my 1988 sigma was never this long.
hcvone
03-22-10, 12:23 PM
I believe it, I had a SL55 Benz and the service manager had a book of the service bulletins, the more electric things on the car/truck the more to go wrong.
