: 1985 deVille ELC (wiring)
03-06-10, 08:32 PM
i put a working compressor from a 86 deville in my 85 the wiring is slightly different so i will not be able to use the quick disconnect wire adapter from my 85 wire harness to the 86 compressor the the wires will have to be matched and crimped/spliced together. there are four wires on the car (the car has, one black, one yellow and two orange wires - the compressor has one black, one green and two orange) does anybody know which colors i should put together? one last thing when i was trying out different wire combinations i blow the fuse in the fuse block and had to replace it, i with the new fuse the compressor still wont activate, is there a secondary fuse or relay that i should check? thanks
