View Full Version : Low Oil Warning comes on but Oil is Full
Vdrenaline
03-06-10, 10:37 AM
I got my oil changed recently and not long after, the "Low Oil Warning" alert started coming on intermittently. I keep checking the oil and it is full. Could the oil shop have knocked or broken the sensor?
Where is the sensor and can I fix it myself?
Any info would be greatly appreciated. Thanks!
SouthernCaddy
03-14-10, 10:43 AM
Are you sure it is not the low oil life warning instead of low oil? If so you can reset it by following the directions on the owners manual. If it is low oil warning, you will need to see if the sensor is unpluged or get a new one installed.
hope this helps.
Punmax
03-15-10, 06:15 AM
Where did you get your oil changed from? I'd bring it in to the dealership ASAP.
