: Rear End Growl
BMBSALES
02-24-10, 11:38 AM
For those that had issues with rear (not your wifes)...what were the signs before it went. mine has gotten loud as hell back there, even with new tires. not sure if it's def the rear though.:lildevil:
bmb
LITTLEELVISDAN
02-24-10, 03:11 PM
TSB on it. either its a rear wheel berring or diff
BMBSALES
02-24-10, 04:36 PM
REALLY! maybe it's just a wheel bearing. didn't know there was tsb on it
jedhead
02-24-10, 05:03 PM
I thought the rear end was starting to fail. The problem turned out to be a wheel hub failure.
BMBSALES
02-24-10, 08:57 PM
I'll check that first then. it's passenger side for sure...if it's not the rear.
BMBSALES
02-25-10, 12:00 PM
anyone have a copy of this tsb. i'm not in front of service manual...are those a hubs a pressed on fit to axle, or simple swap. if i remember the speed sensor is also part of that assembly.
bmb
BMBSALES
02-26-10, 03:10 PM
i may pull the wheels to look at it today
BMBSALES
02-27-10, 10:21 AM
OR I MAY TAKE IT TO THE DAMN DEALER...WHAT WAS I THINKING UNDER THERE! should have gotten extended...:crybaby:
BMBSALES
03-03-10, 04:45 PM
got it back today. right rear hub for me too...
was going to have them put fuel filter on with 65k, but i guess the pressure reg is built into filter and it's $160 list
