rollerz70
08-16-04, 04:14 AM
A couple weeks ago I recharged a almost new battery, it sat for like 2 months in a car that was broke down. I got new terminals for my battery cables, made sure that they were very tight on the posts. The car started right up, and it kept charge for about 5 days. I didn't start the car every day so it drained all the way again! I'm thinking my starter might be the culprit, because when I go to start my car it turns over really slow, and slowly starts to gain speed before it'll start. What would you'll think? Thank you for the help.
barge master
08-16-04, 11:42 AM
It sounds like you've got a weak starter or something, but I doubt the starter is killing the battery. I have seen alternators with an internal short do that though. You could try unhooking the wire from the back and see if it helps.
chuckdobbins
08-17-04, 12:05 AM
same thing happened to me. i was able to hit the starter with a hammer one time to get it started. and it worked again 2 weeks later. but 3rd time was no such luck...
i also had the "slow-motion start up" as i like to call it. i bought a brand new alternator for $139 and was able to switch it out with my fathers help. total time chasing down a new alternator for cheap money and switching bad for good was around 3 hours. just a couple of mounting bolts, a wiring harness and a couple o-ring connections. not sure what car you have but on my 1990 deville i also had to remove the top middle tensioner pulley cuz it was right up against one of the mounting bolts.
however i think my starter is also on the way out as well, but the alternator was a DIY job for me so i did that first and solved my problem.
