View Full Version : speed limiting question
bigds01
02-12-10, 01:24 PM
I posted something in the suspension thread and got 0 responses. What would happen to the electronics on the car if I just put on cheap ass shocks and didn't worry about any of the electronics. Would it cause the car to throw a code a limit the vehicle speed? Any other concerns? Remember this is for the racing caddy.
Submariner409
02-13-10, 11:28 AM
Some stability and/or suspension fault codes will limit speed to 90 mph and also set a DTC.
If the roll, pitch, and yaw sensors (1994 ???) coupled with the signals from ride height and strut/shock operation do not give the "I'm OK" signals to the PCM the fault code and limiter sets.
Submariner409
02-13-10, 05:34 PM
EDIT: I believe that a faulty steering wheel turn rate sensor will also set the 90 mph limiter - it's tied into the stability system.
bigds01
02-13-10, 08:11 PM
What about ripping out the airbags? Is there a way to override the limiter?
Submariner409
02-13-10, 09:07 PM
Talk directly with Wester's Garage concerning your car, what it's going to be used for, and what to do to the PCM.
bigds01
02-13-10, 09:31 PM
Could you pm me contact info.
Thanks
Submariner409
02-13-10, 09:40 PM
Wester's is discussed quite a bit in here and PCM Tuning. Their website has been posted several times in the last 2 weeks - either go back in time a bit or let another member link the site so all can share..................I'm not dissing you - I just want all to be in the same boat.
Google "westers garage" and open the link with "eidnet.org/" in the URL.
