: Big Brakes for EXT Lade
snubdeville
02-06-10, 07:30 PM
Hey all,
Looking for some ideas on "BIG BRAKE" kits for the caddy. I really don't care to spend $6-8k on Brembo brand. Anything larger than stock would be nice, truck is on 22's now and a set of 26's for the summer. I'm noticing very high brake temps around town and I never find myself abusing the brake pedal.
Thanks
krieghoff
02-06-10, 10:10 PM
I can't understand why you would need bigger brakes. The stock brakes on my ESV will stop a 17,000 trailer on the back.
LeftLane
02-06-10, 10:48 PM
Escalade with 22's don't stop all that well.They need a tad bit more brakes.
LeftLane
02-06-10, 10:54 PM
I would go with Baer’s Eradi Speed Plus 1 Rotors.The stock rotors are 13",the Baer's are 15" upfront and 14" in the rear.You can do front and rear for $1100 to your door from AutoAnything.com
http://www.autoanything.com/brakes/61A3974A0A0A2196585.aspx
snubdeville
02-07-10, 09:07 AM
I just replaced brakes and rotors at 25k miles, pads were acceptable but the front rotors had some glazing and much warping. I may just be used to having my Allison trans in the p/u when I can go 75k plus on a set of brakes. I find this truck stopping very poorly without towing.
Thanks for the the replies guys. Keep em coming !
LeftLane
02-07-10, 08:44 PM
Baer Eradi Speed Plus 1 Rotors comes with a Lifetime Warranty against warping
steve841
02-09-10, 06:22 PM
Anyone install these yet? I just went ahead and ordered a set.
Any special tools required? Does the caliper piston need to be compressed?
Big Windy Ext
02-10-10, 08:37 AM
A C-Clamp is all you need to compress your piston . I,m looking forward to your review and install . My only fear is there is computers controlling braking and what the side effects are to the abs and stability controls . Mr Doom .
PreachRR
02-10-10, 12:56 PM
A direct fit component is R1 Concepts drilled and slotted zinc rotors and ceramic pads. put a set on my 03 tahoe with 22s and man those things worked great.. It is a definite for me when the time comes.
http://cgi.ebay.com/ebaymotors/CADILLAC-ESCALADE-07-Brake-Rotors-Ceramic-Pads-F-R_W0QQitemZ220541163238QQcmdZViewItemQQptZMotors_C ar_Truck_Parts_Accessories?hash=item33594716e6
LeftLane
02-11-10, 04:24 AM
does not effect abs or anything else,also you can still use stock brake pads.
steve841
02-11-10, 04:33 PM
Yes ... I confirmed that with Baer before I ordered ... guess they should be here early next week. I will follow up after install.
