: Horn problem
02-01-10, 10:17 PM
I just got a 98 Catera with 24,000 miles from a family member. It's a nice car, but the horn does not work. I replaced the blown fuse, and it worked about five times until the fuse blew again. Any suggestions on where to start fixing this problem? Thanks!
02-01-10, 11:20 PM
probably a short somewhere...
DO NOT PUT HEAVIER FUSE! You will burn something out, perhaps the car sat a long time and connectors corroded so its shorting somewhere causing your horn fuse to burn out...
Do some electrical testing on the wires and see if there is a short somewhere.
02-03-10, 10:29 AM
I removed the horns, and cleaned the electrical connections as well as the connections between the horn, bracket, & frame. All were clean, and had no impact on the problem. Any other suggestions?
02-11-10, 05:07 PM
Does anyone have any suggestions on where to look next? This problem is keeping me from letting my son drive this car. I would appreciate any suggestions you may have.
04-02-10, 02:51 PM
have 1970 deville with horn problem. Horn stuck on but when fuse is taken out the horn stops. How to I trace the wiring/relays to see if that is the problem? No diagram or manual to reference. HELP
