Ive been searching for escalade owners using Royal Purple motore oil but with no luck. Are you using Royal Purple? Have you noticed a difference between other oils? Did it restore horsepower?
I've been using Walmart brand SuperTech Synthetic. I dont see the need to use Royal Purple ($8 a quart!) when my walmart synthetic oil change costs me $19 w/ a filter.
Or you can just use Castrol Syntec (another expensive choice, but great) or i also love Valvoline Synthetic for engines with over 75K miles. It works like a charm.
I'm using Royal Purple Max-Gear Fluid In the front and rear differential and then Royal Purple Synchromax Fluid in the transfer case. I'm at 70,000 miles, but didn't really notice it "restoring power". I just changed it because I knew it would be better for the truck...
Hey before you did the front n rear fluid change, did you experience the typical humming noise? If so did it go away with the royal purple? I always wondered if there was anything out there like Lucas with their addatives for transmissons and engines and so on. I would think Lucas would have something for the diffs and minimize the noise?
Everything we have uses Mobil1.
It's just soo easy to find when you need it.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
