Uncle Hank
08-11-04, 05:59 PM
Where is the location for the Maxi Fuse/Relay Center on a 98 Deville?
I found the Engine compartment fuse block but not the Maxi Fuse/Relay Center.
Thank you!
UH
On some cars like Seville and Eldorado, there is also a fuse block on the side of the trunk. I'm not totally sure about yours though, but you could check.
Hotrodelectric
08-12-04, 05:18 AM
Ok- calling back to the days I turned these into hearses- there is a large plastic cover at the driver side strut tower, to the front. Your maxifuses are under that.
wmarryatt
08-19-04, 01:42 PM
don't guess you would know what the relays are can't find them in a schematic.
Hotrodelectric
08-19-04, 10:58 PM
There are approximately 30-40 relays scattered behind the rear seat and underhood- which ones do you want to know about? :suspect:
Mac McCallum
11-26-04, 01:21 AM
I just spent two hours looking for the Trunk compartment fuse panel location in a 96 Deville. Turns out it is about 6" from the left side of the car mountede on the back of the rear seat. I am 6' 3" tall so with my feet on the ground it is still extremly ackward to read and pull fuses out. I took out way to much trunk carpet. Who would have thought that with the engine compartment fuses in plain sight that Cadilliac would hide the trunk fuses.
