: Blinkers not working now
GreenWood
01-13-10, 11:58 PM
What could this be? all bulbs are good. blinkers don't blink
outsider
01-14-10, 10:21 AM
usually that means one of the bulbs somewhere is burnt. I know in mine, I had a bulb with a broken filiment. it would work sometimes if the filiment touched back over to the right place and other times it would just stay lit and not blink. I would suggest looking closely at each bulb.
Angry Matt
01-14-10, 09:17 PM
Did you check the relay? They're under the dash, small capacitor looking things. You can get them at any parts store, probably under $10. Does the signal stay on steady when you flick it on?
GreenWood
01-15-10, 08:26 PM
yes, it stays on. I did see a block with square shaped blocks plugged into it. It was above the emergency brake. Is this where the relay would be?
thefleetwoodguy
01-15-10, 08:47 PM
no, pass side of the steering column
its round looks like they always did back to the 60's
GreenWood
01-15-10, 08:53 PM
Is it shared with the Hazard lights? or sepeerate? The hazards do blink / work.
csbuckn
01-15-10, 09:26 PM
also known as a flasher, its seperate from the hazards(they have their own flasher). little metal cylinder.
cadi509
01-15-10, 10:04 PM
Ya sounds like a flasher it'll look like this http://www.allproducts.com/ee/zungsung/04-motorcycle_flasher-l.jpg like the top right ones
