Just a heads up to any of the guys on the fence about getting one of these, according to Jeff@SpectacleSolutions (ls1tech sponsor) they are no longer available from fast. So if anyone want's one get it now!
Thats what I'm running......... and there relatively new. They give any reason for dropping the 92 ?, Any problems with it the reason ?
I gained 49 rwhp & 24 rwtq with a much flatter curve going from LS-2 intake to the fast 92, and that with a loss of over 2 lbs boost due to increase flow
Did he say what would take its place? I assume the 96 unit since everyone thinks they need more.
I am shocked that no other company has not come out with a polymer style intake to compete and lower the price on these intakes.
When fast went from the 90 to 92 they made several improvements and raised the price on them and it became the same part number.
The new FAST 102mm can be used with a 90mm or 92mm throttle body so it is backwards compatable. I assume that is why they would discontinue the previous versions. That way they don't have the guess how many of which size to make.
I would like to see an independant evaluation of the Typhoon vs a stock intake. I do not see the need for a 346 or even my 383 to need a 102mm intake. Seems like overkill to me.
I would really like to know more about this intake. Guess I will have to shoot them an email. My guess is no rails or injectors. Heck I would just take the rails and intake.
The Professional Products Typhoon Intake has no affiliation with Maryland Speed. It does come with rails if ordered from Maryland Speed at their advertised price but the rails are also made by Professional Products. You can order the intake alone elsewhere.
Good read, but some little clean up seems to turn out with good numbers. Along those lines, has any one ported (cleaned up) the plastic in takes to match the heads? Since mine are being ported currently this is something I am considering.
im still confused.... what is the intake manifold part number on the LS6 - 05V? what size throttle body is it? Are the manifolds sized or have the bolt pattern for the specific TB?.. I'm looking for a direct replacement for mine for an experiment.
05 throttle is 78mm Electronic Throttle, with coolant passage.
Stock TB Flow @ 10" 529cfm Stock TB Flow @ 28" 885cfm - part number # cant remember.. who cares really, these are ETC with a driver side motor, 3 bolt.
A 90 mm throttle, aka ls2 is 4 bolt, Part# 12570790 with passenger motor, flows closer to 1200cfm.
Ls6 manifold part # 12573572
Im sure someone can add to this... old thread though...
So can I get a tpis (vendor?) Manifold With a larger TB to fit my LS6 and not encounter problems? Would I need a new MAF and tune since I have headers with w4m tune? I don't need to worry about larger injectors unless maggie right? Really looking for a replacement intake to have coated, but would rather coat one onn the shelf so I can swap once done. And if I can upgrade in the process... Then What the heck. What you guys suggestions?
TPIS (www.tpis.com) supplied me with an LS6 manifold, an LS2 Throttle body, and a wiring harness (the LS2 TB has a different number of plug-ins). They will take you old manifold as trade-in/echange. The whole thing bolted right up and required no tuning. (My tuner, PatrickG told me in advance that it would require no tuning.). It netted about 15 hp on mine, which already had a mild cam.
I just picked up a 102 LSR intake from fast. A little pricey but it will be able to sustain my flow needs later in the near future for a big cube short block. It has individual removable runners that can be ported with ease or if one cracks or whatever I can just replace that one. Its got a bunch of nice features I liked. It's like a 92 but on steroids.
UWOOD....
can you provide like or site to get the wiring conversion? I want the modified ls6 manifold from TPIS but not very cool on their $470 throttle body. I have an ls2 TB, just need to better understand the swap and wiring.
Anyone...
Anyone have a procedure, in the service manual or otherwise, to remove the intake manifold and possibly the fual rails???? I want to remove, coat and reinstall. whos got the answers?
Fuel rails are 4 bolts and the manifold is just as easy ... remember the MAP and other vac lines on the back of the manifold. I have a large word doc on this.. just been busy with 'actual work' to post these procedures.
to remove the fuel lines you need what is called an A/C & Fuel line quick disconnect... (they are cheap plastic things.. ) you wrap around the line and PUSH away from the rail.. if you push the plastic inside the sleeve and try to pull apart.. you will be fighting it.. just keep sliding the plastic disconnect and push into the main line away from the rail.. it will come apart. the main line is a different size than the Evap line...all that has to be removed as well... the coolant line under the throttle, any brackets across the stock manifold, rails.
unclip using TWO flat head screwdrivers and press (squeeze) the clips INTO the injector to release. yea.. should have got on that procedure doc...sorry. I believe everything is 10mm. The wiring harness will have 4 plastic clips as well, in the back.. brake booster and MAP sensor... (smaller bolt from what i remember)
once you are ready to remove the rails.. its best to keep the injectors ON the rails... Grab firmly with one hand on each side, and rock front to back while pulling up to break the 'seal'... if that makes sense... easiest way I have found, sorry jumping around, just adding by memory
Example of a quick disconnect
I wont be able to send you docs at this moment... at my other shop.
I went with the Fast 92mm and hand ported 90mm LS2 throttle...
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
