View Full Version : 92 deville running power wire through firewall were?
RiZzLe7
01-13-10, 05:32 AM
i cant find any spots to do this. any help much apreciated.
pics if u have some
cadi509
01-18-10, 11:37 PM
On my 93 I rolled the carpet back and drilled about a 1/2 hole through on the passenger side then used a grommet to seal everything up, idk if your willing to do that but I never had any problems, and also when you run the wires by the passenger seat DON'T, remove the whole seat (very easy and worth your time) roll the carpet completly back and you'll see a hole that you can run the wires through on the seat frame safely, reason being when I ran my wires the first time my + wire got smashed and grounded out.
still_walkin
02-21-10, 08:58 AM
To saved time run your amp wire on the same side your battery is and I agree with the post above there is a spot under the seat to run it. And use a grommet u don't want water in your car.
