: 93 deville suspension
mike93
01-10-10, 06:36 PM
Hi everyone how are you doing I hve 1993 cadillac deville 4.9 and was wondering if I should put air shocks back on the car or passive shocks because next month im putting new shocks all around and want to know what do you think should i do idc about the air shocks all I want is for my car to sit up nice not low like it's sitting right now im also putting all new coil spring so what do you think I should do?
Submariner409
01-15-10, 09:33 AM
If you have the time and $$$, rebuild the suspension back to stock (including the rear level system) for that nice Cadillac ride and control.
Otherwise, start searching the aftermarket spring and strut/shock sites for passive replacements.
mike93
01-19-10, 05:42 PM
Car sits low shocks are not leaking why is car sitting so low and the shocks are not leaking?
Cadillac_Phx
01-19-10, 07:22 PM
I'm about to replace my suspension too. I'm going to do it in 2-3 weeks from now. I'm replacing my front struts & rear air shocks with ALL Arnott Industries parts. After doing extensive research I've come to find that all caddy owners who use Arnott get Great, satisfying results & no SERVICE RIDE CONTROL message!! I'm going to replace the springs as well, I'm getting those from the dealer but I might look around to see where they're cheaper. I think Eibach springs lower your vehicle so I'm not going for those. GOOD LUCK MAN!!
mike93
01-19-10, 08:38 PM
Oh ok cool yeah im gonna be doing it soon front and rear spring something thats gonna make the car sit nice and high
brandond25
01-23-10, 07:58 PM
Could be the pump that puts the air to your rear shocks is not working. Or bad springs. If your shocks dont leak its one or the other. Unless you have a ton of weight in the rear maybe.
revdowrong
01-31-10, 03:49 PM
On my cadillac I replaced my rear springs with Rear Variable Rate Coil Springs and replace the air struts and it no longer sags in the back. To make sure the air struts have air see if you can squeeze the air bladder on the struts. Thats what I do to make sure the air struts don't have a leak. When you do decide to get springs get Rear Variable Rate Coil Springs because they get firmer when there is added weight.
CaddilacJohn
06-17-16, 09:20 AM
Can the Arnott 94 Deville Rear Air Struts be used on a 93 Deville? For some odd reason Arnott does not any replacements for the 91-93 Deville.
Thx
basscatt
06-19-16, 03:27 PM
Thx
to answer your question - NO -
the 93 uses rear struts - the 94 uses rear shocks -
it has a completely different rear suspension system -
the stuff from arnott is WAY overpriced CRAP -
what you NEED is the MONROE 71798 - and I found you a KILLER DEAL for you -
$50 each - with free shipping -
http://www.ebay.com/itm/Monroe-71798-Suspension-Strut-Assembly-Rear-/251799662755?hash=item3aa06df0a3:m:m78gIEpbeWP4ZK0 5oUiPARA&vxp=mtr
CoupeD
12-18-16, 04:56 PM
Hello,
Is it OK to continue this thread or should I start a new?
93 deville here. I recently replaced struts and springs front and rear. Moog springs and AC Delco struts.
Rear struts are ACDelco 903-002RS. The rear springs are MOOG CC653. The rear of the car is riding horribly. Ride height seems OK, but the car rides so hard in the rear it is making me nauseous to drive. I thought maybe the air ride isn't purging properly so I disconnected the air hoses at the strut. The car still rides the same.
Does anyone have any insight? Could the struts have seized? I can hear the brand new strut mount in the rear is broken because of how hard it is riding.
