: Level ride compressor on the fritz 94 FWB
425 Dual Quad
01-10-10, 10:52 AM
Hi all,
The level ride compressor on my 94 Fleetwood is on the fritz. It wont shut off. I suspect an air leak underneath because I can hear hissing as the compressor runs. Could be the shock bags or a line. Anyways it ran the battery down yesterday so I had to jump start the car. Not good.
Is there a way of disabling the compressor until I can get under it to see. It's swnowing here!
regards & thanks, Nick
thefleetwoodguy
01-10-10, 11:16 AM
yes if its not burned up yet
under hood fuse block pass side its a green 30 amp large fuse
the cover of the fuse block will tell you which one
if you need to replace the shocks I have a decent set
Jim
425 Dual Quad
01-10-10, 01:25 PM
Hey Jim,
Many thanks - might have known you would be the first to reply. Many thanks mate. I'll pull the fuse/ relay in the morning when it's light. Battery is disconnected now - and check the air lines when I can get under, poss in the week.
Tell me, the shocks - are the the same as air shocks that would fit a '70/ '72 Chevelle, only a buddy has some spare. Not sure on teh length tho. I guess the top fittings ( 2 3/8 bolts) and the bottom fittings (eye) are the same.
How much did u want for the shocks? you can mail me with the price if you prefer.
How's the snow in NH?
regards, Nick
thefleetwoodguy
01-10-10, 01:30 PM
Hey Jim,
regards, Nick
Nick
not sure if the chevy shocks would work
best bet it do a comparison on them make sure they have the same amount of travel
get a sponge with some soapy water and go over the fittings looking for bubbles, may be a loose airline nut at the shock, if your lucky
no too much snow here but bitterly cold
it was down to 3 deg f last night,
finally got my garage insulated and heated so I can have some fun time this winter.....let us know how things pan out Jimbo
425 Dual Quad
01-10-10, 02:50 PM
Jim,
thanks for the tips - fuse number 9, 30 A megafuse. Stopped it mid cycle. Many thanks. Wow 3 degrees! It was 26 here and we all thought that was cold!
