: How do you remove the rear door panel & replace a window motor on an '01?
bacardi
01-07-10, 11:19 PM
Have a replacement regulator. How do I replace it?
Thanks
Black02SLPSS
01-14-10, 04:55 AM
Generally there are a few fastners holding the panel to the door, then once those are out the panel should slide off. Most likely up. Now for the regulator, that will probably be riveted to the door (not entirely sure since i have not done one on a catera, just referencing from doing them in my camaro). If they are indeed riveted, you will need to drill them out and then your motor/regulator should slide along the tracks and out of a little bullshit hole that its suppost to fit thru. Then you just swap them out and repeat the process in reverse.
Or you could just take it to someone.
bacardi
01-17-10, 11:29 AM
Thanks
