First I lost the dash lights,jumpered it at the headlight switch until new switch arrived. Just put the new switch in,have dash lights without a jumper but no lights on any of the door switches/buttons.
All fuses are good. Any suggestions?
02 lade
Only in the drivers door. I can get the lights for the window switches and the power mirror to turn on if I hit it just right with my fist. They will stay on till the next ignition off-on cycle. The light for the heated seat switch are dead on the drivers side, ok on passenger side. I'll get to those after the steering wheel controls.
where did you hit it?
Im wondering if dimmer circuit at headlight switch is to blame....
My dash lights went out,jumpered the headlight switch and got them to work
until my new HL switch came in and now this,never have gotten the door button lights to work.
I'll try and get the wiring diagram for the driver door switches tomorrow. You could start testing there, the panel with the window switches comes off easily.
I could not find a specific diagram for the driver door switches. SI manual is pretty general about troubleshooting procedures, is the ILLUM fuse ok? Since all doors have no power, I would also assume the switch is to blame. Start from there with your test light and post back.
I replaced all of my window switches with LEDs. They worked great...for about 1 week...then all at once, every single one of the door lock and window switches quit working. I could understand if one LED light went out or one door...but not all four door....I've check every fuse with no luck...
all the door locks, and windows still work fine...just no illumination
let me know if you figure it out....something got shorted out somewhere I would guess..
I had 2 different problems,a blown 10A fuse and a bad dimmer circuit on a new replacement Delco
headlight switch. Since the ebay seller wouldnt respond to a replacement for bad switch,I fixed my old one by soldering a small jumper across the trace. Mine works fine now,just burns me that a legit ebay seller wont even respond.
SK7 Can you please help me on getting a service manual to show some wiring diagrams for the rear heater circuit. my heater/cooler works but I can't control the level zones (foot, head or bi-level) from the main control or neither the center console controller. I changed the activators (pic below) already (no luck there) but I can't find the Body module for all this.
Kagscrew, I got my GM SI manual from blownc5 on this forum. Its a must have! Lmk what year/model your truck is and I can get some troubleshooting tips from the manual.
Sk7:
I have a 03 base model and since last summer I have been trying to fix this problem. Please PM whatever tips or drawing you think can help me.
(I got a link from Bill to order GM SI manual $183.)
I've got the same issue with the switches not lighting up on my doors. Never really bothered to try and fix it, but if anyone finds a common problem i'd sure like to know.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
