: Removing license plate bulbs on 2000 caters
Dtz7635
01-02-10, 02:10 AM
This may be a dumb question but how do I remove the license plate bulbs on my cater... I unscrew the 2 screws holding the light in but can't figure out how to get the bulb out. Any help would be great.
bacardi
01-02-10, 03:39 PM
There's two screws per side, T15 torx...They need to be removed.
Try pulling the whole assembly straight down. If it doesn't come out by hand, carefully use a flathead screwdriver to pry it out.
Once it's pulled down, if you prefer easier you can disconnect the two wiring pigtails or leave it connected.
Pull back the rubber boot on the back/sides, you'll than be able to access the bulbs.
Bulb size is 6418. If one has already gone out, I'd go ahead and replace them both.
http://base1.googlehosted.com/base_media?q=http://www.elightbulbs.com/catpics/eiko/40675.jpg&size=19&dhm=36459d7e&hl=en
Dtz7635
01-02-10, 09:18 PM
Got em changed. Thanks a lot.
CateraMV6
01-02-10, 10:49 PM
I installed LEDs in mine and loved the results, you should dig around here for some more pictures...
Good luck.
Dtz7635
01-05-10, 03:29 AM
Good luck.
Ya I like that look.. Btw I've been lookin to get an Opel grill for my 00 but can't really find one.. Where'd u get yours?
