: Anyone have any idea how to remove this steering pulley?
69Deville
12-28-09, 07:09 PM
So I tried with one of those "universal" pullers with no avail. I hope I'm just doing something wrong here, cause as of now I'm running under the assumption that the dark lord himself designed this. Any ideas?
http://i.imgur.com/RrhI2.jpg
http://i.imgur.com/vKFi0.jpg
HUF
12-28-09, 07:18 PM
Were you able to take off the nut?
69Deville
12-28-09, 07:21 PM
I just can't figure out how to keep the pulley still without damaging it. Otherwise this is a 2 second job.
HUF
12-28-09, 07:58 PM
You did not answer the question... Put the belt back, and keep it in place with the belt.
69Deville
12-28-09, 10:43 PM
What I meant to say was no. That was the first thing I tried but there is not enough tension, belt slips. That nut is on tight.
csbuckn
12-29-09, 01:23 AM
they might make an oil filter strap type tool big enough to hold it, maybe wrap a belt around it to help hold it.
69Deville
12-29-09, 10:41 PM
That sounded like a great idea so I went out and got the biggest filter strap I can find, 6 inch, but it was still too much. So i just decided to bring out some bigger toys and put more elbow grease on it. Finally got it to work using a breaker bar and a crow bar. The problem I found out was that the nut was cross threaded. :banghead:
supercad1
12-29-09, 11:05 PM
Find a belt to keep the pulley from moving, then put a long pipe to a socket and try to remove that nut, my suggestion.
69Deville
12-29-09, 11:48 PM
This is what worked:
http://i.imgur.com/zrhCZ.jpg
