View Full Version : many OBD II codes on 3.2
fritoss007
12-15-09, 09:08 PM
Hi, my car is giving me many code at the same times...
here is the list :
0221
0507
0700
1779
1795
when the above codes are cleared then i got :
2176
finally when all codes are cleared...the car goes right for 3-5 days....
2 times now...same result
any ideas ?
thanks alot
Coke_O
03-13-10, 05:00 PM
P0221 - APP (Throttle Position) Sensor 2 Circuit Performance
C0221 - Right Front Wheel Speed Sensor Circuit Open
P0507 - Idle Speed High
P0700 - Transmission Control System Malfunction
P1779 - Engine Torque Delivered to TCM Signal
P1795 - CAN Bus - Throttle Body Position
P2176 - Minimum Throttle Position Not Learned
You should read up on some of the threads that are out there. There is a lot of talk about a crankshaft position sensor. My car spews out those sames codes when it is warm outside. During cold weather it works fine. I've replaced the throttle body with no luck. My next move is to replace the crankshaft position sensor. Good luck.
-coke_o
concorso
03-17-10, 11:43 AM
You may want to post this in the CTS forum.
