: where do i find build date?
12-12-09, 09:00 PM
anyone know?
12-12-09, 10:00 PM
open the driver's side door, if you look down you'll see a sticker with recommended tire pressures...under that is a big silver sticker with the build info. don't get distracted by the tire pressure sticker...LOL...took me a while to see the humongous build sticker because i was fixated on proper inflation.
12-13-09, 08:53 PM
It should be emphasized that the tire pressure sticker and the build date sticker are two different stickers. The tire pressure sticker faces up when the door is opened and is probably the first one seen. The "big silver sticker," referred to by ecorpuz12, is below the tire pressure sticker on a surface at a right angle to the surface that the tire pressure sticker is on. It faces to the side of the car and is not nearly as obvious as the tire pressure sticker.
