: Gas pedal click
Fantom Infinity
08-07-04, 06:03 PM
When I turn my car off after a drive, my gas pedal will click, and something else under the hood clicks as well. I'll take a pic of the part and circle it and upload it, because I have no idea what it is. I recently noticed that it also starts clicking if I turn the car to accessory, then it will stop. Then once I turn the car off again it does it again and then stops. The whole pedal moves, and just goes *click* *click* *click* *click.* It's very strange. No clue what it is, but I'm guessing someone out there might.
shaunp05
08-07-04, 06:39 PM
That might be the I.A.C valve resetting itself. Its a sign you going to be
needing one sooner or later
eldorado1
08-07-04, 09:58 PM
Yep. The ISC(M) on the 93-95's actually move the entire throttle plate (which the gas pedal is connected to). This is in contrast to the later models (and almost all other late model GM engines) that use a stepper motor to move a pintle opening/closing up an "air bypass" in the throttle body.
Ranger
08-08-04, 10:17 PM
I am pretty sure that is normal. It is just adjusting it self. I wouldn't worry about it.
