View Full Version : Woohoo, 10 for 10 march built cars with loose bolts..
wait4me
12-11-09, 02:55 PM
Just so you guys know, if your car is built on march, then you need to grab a 10mm socket and go tighten the TOP left bolt on your throttlebody. EVERY one i get here that was a march build has that one bolt loose or missing... Just a heads up..
nynd
12-11-09, 03:02 PM
Got a pic.. which bolt?
neuronbob
12-11-09, 04:39 PM
:werd:
Do share a pic.
Hawkeye2
12-11-09, 05:10 PM
Great I'm a March build. I stored my car.....give me something to do this weekend....
mpouls1
12-12-09, 12:29 PM
mine is march. i will take a look later. "baby it's cold outside.." if any are loose or missing and nobody has yet, i will take a pic (he did say TOP left).
Thanks Jess
michael
asabase
12-12-09, 12:42 PM
Mine is 02/09 and they were tight.
GM-4-LIFE
12-12-09, 07:38 PM
Hopefully, GM found the problem at the factory and FIRED IT!
SG
qtzman
12-12-09, 07:56 PM
mine is2/09 had rear tie rods bolts not tight it nearly killed me!
asabase
12-12-09, 08:27 PM
guess ill try and get mine on ramps tomorrow and check everything under it.
CTS NV
12-12-09, 11:35 PM
Argh...I have a March build. Will wait for a pic...
CoOlSlY
12-13-09, 10:37 AM
I see a lot of people saying they have some built/quality. I thought that a high-end car as the Cadillac would have more quality control. Don't get me wrong, I have a V on order but still, i'm surprised to read how many people have bolts/fluid/fitting issues!
Mikevette
12-13-09, 11:14 AM
Jess
Thanks for your input on this throttle body bolt issue. I checked my throttle body bolt you mentioned, sure enough it was loose that I could put 1 1/2 turns to snug it up!!!!! Thanks for your input ! My car was an 03/09 build
Mike P. :nono:
ecorpuz12
12-13-09, 11:26 AM
maybe the throttle body bolt tightening robot was suffering from the y2k9 bug. or it was the chinese hacking into the software programming...
asabase
12-13-09, 12:02 PM
My power steering fluid was low when I got mine so you might want to check that too.
tbss08
12-13-09, 01:50 PM
Checked my bolt for a 03/09 build and it was tight.
