: 1990 Brougham rear speaker removal
12-11-09, 02:00 PM
By chance does anyone know how to remove the rear speakers from a 1990 Brougham?
It has a third brake light and the seatbelts anchor on the rear deck.
Any help would be greatly appreciated.
12-11-09, 03:05 PM
should be pretty simple. Go into the trunk and you should be able to see the bolts holding them down.
12-11-09, 03:06 PM
I believe you can simply pull them out from in the trunk, not sure though. I am planning on doing mine this spring.
12-13-09, 12:02 PM
Very simple, Inside the trunk you will see the speakers mounted underneath the rear deck. NO tools required! There should be a black cardboard cover on there with a plastic nut that you can unscrew with your hand. Once you get that off, the speakers are held in with a metal bracket. It's only held in with tension. Just pop it out and then unplug the wires, and you are golden. Hope this helps.
12-13-09, 02:50 PM
Takes 5 min.
