View Full Version : 2003 Cadillac CTS Specifications
BeelzeBob
01-22-03, 05:38 PM
Dimensions:
Length 190.1"
Height 56.7"
Width 70.6"
Wheelbase 113.4"
Trailer towing 1,000 lbs.*
Curb weight:
manual 3,509 lbs.
automatic 3,568 lbs.
Capacities:
Seating 5-passenger
Cargo volume 12.8 cu. ft.
Head room:
front 38.9"
rear 36.9"
Leg room:
front 42.4"
rear 36.2"
Hip room:
front 53.4"
rear 53.8"
Shoulder room:
front 56.6"
rear 56.2"
KEY: S (Standard) A (Available) - (Unavailable) | (Included)
(CTS, Luxury Package, Luxury Sport Package)
Powertrain:
3.2L V6 DOHC with 220 hp at 6,000 rpm and 220 ft-lbs at 3,400 rpm S S S
Rear-wheel drive S S S
Engine block heater** - A** A**
Getrag manual 5-speed transmission with mechanical shift linkage S S S
Automatic 5-speed transmission 5L40-E Hydra-Matic with electronic controls, includes winter and sport modes A A A
Chassis & Suspension - All-Speed Traction Control:
Brake and engine control S S S
Sport-tuned suspension:
Includes monotube performance shocks - - |
Brakes:
4-wheel ventilated anti-lock disc brakes S S S
High-performance brake lining - - |
Suspension:
Front: Independent short/long arm, coil over dampers with anti-sway bar S S S
Rear: Independent, modified multi-link with anti-sway bar S S S
Load-leveling rear suspension - - |
StabiliTrak
Computer-controlled stability enhancement system - - |
Steering:
Power-assisted rack-and-pinion S S -
Power-assisted speed-sensitive rack-and-pinion - - |
Wheels/Tires:
16" x 7" cast aluminum painted with all-season P225/55R-16 H-rated (130 mph @ 30 psi) blackwall S - -
16" x 7" cast aluminum machined bright finish with all-season P225/55R-16 H-rated (126 mph @ 30 psi) blackwall - A -
17" x 7.5" cast aluminum machined bright finish with all-season P225/50R-17 W-rated (161 mph @ 30 psi) blackwall - - S
17" x 7.5" cast aluminum mirror-polished with all-season P225/50R-17 W-rated (161 mph @30psi) blackwall - - A
*Maximum trailer-weight ratings are calculated assuming a base vehicle, except for any option(s) necessary to achieve the rating, plus driver. The weight of other optional equipment, passengers, and cargo will reduce the maximum trailer weight your vehicle can tow. See your Cadillac dealer for additional details.
**Requires heated seats.
