dat108man
08-07-04, 03:30 AM
Is there any problems with putting 20 inch rims on a 95 deville. I was actually interested in buying these rims off ebay, if anyone has any info or suggestions i would appreciate it. Also is a 95 deville front wheel or rear wheel drive?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&tc=photo&item=7914408751&category=43960
elwesso
08-07-04, 10:58 AM
I never recommend putting that big of rims on a car like this because the tires you will have to use wil be MUCH to thin (not enough sidewall) and one big pothole and they will bent forever.....
Those rims look very cheap and I doubt they would have the right load capacity. The deville is a HEAVY car..... Plus, they dont list the bolt pattern and offset so you have no way of knowing if they will even FIT...
I recommend finding some good 17 or 18s, not tomention tires are MUCH cheaper and you wont lose much ride quality (20s will be very harsh)..
The deville is FWD.....
I would go on to tirerack.com and get rims from there.. All of them are as good or better than OEM, so you will not have to worry about the tires outlasting the rims... :)
If you want to go ebay, be sure to make sure they will handle the weight..... They may "fit" but they wont be suitable for use....
elwesso
08-07-04, 10:59 AM
BTW... Welcome aboard, thanks for signing up :wave:
dat108man
08-08-04, 04:20 AM
i appreciate ur help and information..i am also looking at these rims on ebay..do u know anything about them and if escalade and deville have same pattern?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7914752839&category=43958
elwesso
08-08-04, 11:00 AM
No escalade rims hav 6 bolts, the deville's have 5 bolt...
RBraczyk
08-08-04, 04:16 PM
Yea, and another thing with heavy rims is your transmission life gets cut in half. Its too much of a strain on it.
elwesso
08-08-04, 08:35 PM
I disagree.. The rims wont weigh THAT much more to decrease tranny life.....
Sure it may decrease the life, but hardly measureable.....
RBraczyk
08-08-04, 09:40 PM
Then what do you think happened to slick black cadillac, his rims killed his tranny...
dat108man
08-08-04, 09:46 PM
can someone check the picture out of these rims and be able to tell if they may fit with a 95 deville
RBraczyk
08-08-04, 10:43 PM
You need to ask the guy if its 115 pattern or not, if it is, your all set.
