: Pulleys... A good source?
12-03-09, 04:38 PM
Does anyone know of a good source for the pulleys that operate with the water pump? I need the one that comes off the end of the cam shaft that drives the pump and the smaller tensioner pulley...at reasonable prices. Any help on this would be great.
12-03-09, 04:56 PM
Main drive pulley - dealer only. Special order (or junkyard). You'll need a claw puller that fits the groove in the metal hub and a proper bolt and greased stack of washers to press the new pulley on. DO NOT tap or hammer the new pulley on - big repair bucks to cams and bearings.
Tensioners, belts and tensioner parts from www.rockauto.com.
You may still have a plastic trim screw in the end of the cam..........thread protector.
