: 91 Brougham wet passenger floor
vpatasce
11-28-09, 01:11 PM
My 91 Brougham has a wet passanger side floor, dfront and rear since driving in the rain. We've had a lot recently. The windshield does not leak. The carpet on the sides of the foot well isn't wet. I looked underneath and there's an oval shaped opening stamped in the steel but when I tap it, it's solid.
Any ideas?
Thanks,
Vince
75 Coupe
11-28-09, 01:32 PM
Does it smell like coolant ?
It may be a bad heater core...
creeker
11-28-09, 04:02 PM
Any ideas?
Thanks,
Vince
You didn't say if you have a sun roof or not,if so it could be clogged drain lines.
vpatasce
11-30-09, 01:22 AM
It does not smell like anti freeze and I do not have a sun roof. Since the rain stopped, the floor has dried out. I'm going to not drive it in the rain until I get this figured out.
robb257731
11-30-09, 02:25 PM
I had the same issue in my 1992 Brougham. Always seemed to happen while it was raining, so like you I thought it was the windshield leaking, or a hole in the floor. I had both checked and they were fine. Turned out it was the air conditioner...We had a really rainy summer, and it seemed the floor was always wet. Finally we had a good hot day, and I took the car to the beach...probably 2 hours each way with the AC on the whole time. My friend put his bare foot down on the floor and it was soaked with freezing cold water. A drain must have been plugged. The damp/wet floor didn't only happen in the summer though, but I believe the ac compressor runs when the temp is on auto, so that would account for the year round damp. Check yours out.
mjs182004
11-30-09, 11:52 PM
Also check your door seals.
vpatasce
12-01-09, 01:33 AM
WOW! Thank you! I didn't think about the condensate drain. I will let you know what I find.
robb257731
12-01-09, 09:09 AM
When I sold Edward (that's what I called the Brougham), I took the buyer out for a test drive. Again, really hot, humid day. I had the AC on. I had taken him out for a few kms, and on the way home I caught some movement out of the corner of my eye....I looked down and there was a STREAM of water coming down from under the passenger side dash. It was like someone had turned on a tap. Thank god the guy was a bit of a redneck and was wearing construction boots! He bought the car and we were both happy!
vpatasce
12-02-09, 07:44 PM
I recently had the AC worked on. This afternoon it was raining and I went out to check the car. Hadn't even driven it in the rain and there was a puddle of water on the floor coming from under the dash! I called the guy that worked on it and he's going to check it out and see if he missed a spot sealing it up after he replaced the evaporator (don't ask).
Vince
greencadillacmatt
12-02-09, 11:38 PM
Have him find and clear the AC drain while he's at it. I have heard of some cars holding over a gallon because of clogged drains. Can you hear a sloshing noise when driving?
vpatasce
12-04-09, 08:56 PM
Vince
Well, the verdict is in. The AC part on the firewall hadn't been sealed properly after the evaporator was replaced. YAY! Hopefully it's dry from now on.
greencadillacmatt
12-05-09, 03:53 AM
Well good. I'm glad that was sorted out, and your passenger's feet will be dry. :)
