View Full Version : Ac
ladder1
08-05-04, 04:29 PM
When my ac is on the passanger side is much warmer even though the tep.is set low. Is the Door/Gate stuck.does it need to be replaced?is this the problem? or could it be something there r no codes listed when the heat is turned on its fine What do u think......................................
johnny133
08-05-04, 05:21 PM
It could be stuck. I read a post here where someone recommended using the control to adjust the passenger side temp all the way to max and then back down. In that case it worked. There is also a way to reprogram the door actuator, but I don't know how to do it. Search the forums using keyword like A/C, ACC, passenger temp, etc. I know I've seen this discussed in these forums. Good Luck
Ranger
08-05-04, 09:26 PM
I have that same problem occassionally. I'm pretty sure the actuator sticks once in a while. I simply run the temp control all the way up to 90 then back down to 70 and it works as it is supposed to after that.
