: 98 Catera HCV relocated!!!
retho78
11-09-09, 11:17 PM
Hi Folks,
This past weekend I did a little modification to the heater control valve on my catera. First, the reason I did this is because its a pain to get to it and second, also spending hours to replace it at least every two years. I decided to relocate it for easy access if it goes bad again. I have also attached the links so you can see, let me know what you think. Your opinions are appreciated.
http://s513.photobucket.com/albums/t334/rtt78/?action=view&current=IMG_1546.jpg&newest=1
http://s513.photobucket.com/albums/t334/rtt78/?action=view&current=IMG_1551.jpg&newest=1
http://s513.photobucket.com/albums/t334/rtt78/?action=view&current=IMG_1550.jpg&newest=1
http://s513.photobucket.com/albums/t334/rtt78/?action=view&current=IMG_1549.jpg&newest=1
http://s513.photobucket.com/albums/t334/rtt78/?action=view&current=IMG_1547.jpg&newest=1
Thanks.
CateraMV6
11-10-09, 01:10 AM
http://i513.photobucket.com/albums/t334/rtt78/IMG_1546.jpg
http://i513.photobucket.com/albums/t334/rtt78/IMG_1551.jpg
http://i513.photobucket.com/albums/t334/rtt78/IMG_1550.jpg
http://i513.photobucket.com/albums/t334/rtt78/IMG_1549.jpg
http://i513.photobucket.com/albums/t334/rtt78/IMG_1547.jpg
CateraMV6
11-10-09, 01:10 AM
Nice mod!
retho78
11-10-09, 04:26 PM
Thanks!!!
xanax06
11-12-09, 07:30 PM
Any pics of how you accessed it to start with?
Very good idea.
Matera97
11-13-09, 03:13 PM
I just picked up a HCV for $15 dollars, woohoo
xanax06
11-16-09, 11:41 PM
I paid 50$ for mine. :ripped:
catera00
11-19-09, 01:38 PM
brilliant! How did you connect the tubes behind the motor?
retho78
11-29-09, 04:13 PM
I bought some additional hose, some heater hose connectors and..... lots of thinking :-). I had to wrap some teflon tapes around the heater hose connectors to make sure they were secure enough and offcourse hose clamps to tighten it.
PrimeTimeElite
12-01-09, 11:44 AM
Impressive! Wish I had seen this post earlier when I replaced the HCV on my '99. I even bought some heater hose and clamps in case the existing ones needed replacement. Maybe next time... :yup:
retho78
02-19-11, 09:30 AM
Just curious, has anyone else tried this...did it work for you?
AHazzardToAll
02-19-11, 11:16 AM
I did this on my sister's 99. So far so good.
hgqguy
02-19-11, 01:57 PM
So... my catera takes forever to get good heat.. is that a bad HCV? and should I have it replaced?? the car is going in on monday..
The car is warm after about 10-15min of driving.. but It litterally has to be on for at least 10 min befor it starts getting warm at all.
AHazzardToAll
02-19-11, 11:21 PM
Mine takes a good 8min or so, I assume it is normal. I've never really looked at the tubing but I've always guessed it had something to do with the thermostat staying closed to get the motor to normal operating temp. Never put that much though into it though.
retho78
02-19-11, 11:35 PM
cool deal "AhazzardToAll".
AHazzardToAll
02-20-11, 12:33 AM
I got the nickname Luke Duke in the middleschool years. Followed me into my paintball career, and we started with the name a hazard to all, and quickly transformed to a hazzard to all, and it stuck to me after that. ;)
retho78
02-21-11, 11:47 PM
Interesting!!!
retho78
05-06-12, 12:55 AM
Hi all,
Just curious to hear from those that did this mod, have you had to replace the HCV or had any issues? Mine is still running strong for the past three years with no changes......thanks.
catera00
05-14-12, 10:51 PM
I completely removed mine about a year ago and have had zero problems.
retho78
05-15-12, 04:01 PM
so you don't have an HCV in the car? What did you do?
elvin315
05-15-12, 04:05 PM
Of course you don't. You're in a desert and don't need a heater control.
catera00
05-26-12, 09:46 AM
I bought a "T" connector and attached all the hoses to it and plugged the vacuum line. My heater and a/c work fine still. I don't know what the point if the HCV is
investor74
05-26-12, 10:48 PM
Supposedly, the purpose of the HCV is to allow the A/C to work better. When the A/C is on max, it short circuits the hot water so that the radiator is not heating up the air ducts and working against cooling the air. But it surely is a sore spot on the Catera.
retho78
06-08-13, 05:41 PM
Hello all,
Just checking again with those that did the Heater control valve modification.....any issues with your car or HCV failing after this mod?
Mine is still running good since I did this mod and haven't had any failure with it, still using the same one.
Keep me posted!!!
Thanks.
