View Full Version : Air shocks won't deflate
Les Saville
11-06-09, 10:28 PM
I have a service ride control message and it appears the shocks are at full extension on my 03 Escalade. I did a search on this and found just the opposite of my problem.
Thanks in advance for any thoughts.
auberypn
11-07-09, 01:13 AM
Hey les i am a newbie, but have the same problem with my service ride control on dashboard. I am shopping around, the Arnott shocks seems to be pretty good,and would like to know what you discover. Thanks,my ride is 2003 ext
Les Saville
11-16-09, 03:16 PM
Anybody have even a hint on what I should look for with this problem?
WSLN 6
11-16-09, 10:34 PM
Does the compressor try and cycle when you start the truck? Sounds like the exhaust solenoid is not letting the pressure drop, maybe the solenoid itself is stuck.
Les Saville
11-17-09, 11:38 PM
Compressor never cycles at start up. Where is the exhaust solenoid?
Thanks in advance for the help.
sk7
11-20-09, 08:17 PM
That's a first allright! The system is not completely leak free, so after sitting overnight, suspension must be at zero pressure. I don't recall a code for too much pressure in the system, but when you first start up the truck in the morning, compressor must run for a long time? There is a trouble code if the compressor runs for a set lenght of time without any change in the ride height. Solenoid exhaust valve and pressure sensor are build into the compressor assembly, behind rear tire left side. Since the compressor is working, exhaust solenoid must be ok. Its either a no signal from the pressure sensor or the level sensors at the SCM. All 3 are 0-5V reference and can be easily tested at the SCM.
