View Full Version : 05 SRX Bose Stereo EQ
caddysrx05
11-06-09, 11:53 AM
Hi, I have a 2005 SRX with the Bose Stereo and I was wondering whether anyone knows whether if you customize the Base, Equilizer, etc. while your on the preset EQ settings, does it change them permenantly, or do they reset as soon as you go through again and and select the same one again. The reason why I'm asking is because in my opinion the system doesn't sound as good as it used to, and I'm thinking it was from people playing around with it.
If I did infact change the original settings, is there anyway to reset them?
Thanks.
TTopJohn
11-10-09, 10:59 AM
I've noticed that a DSP setting can get associated with a particular preset. And the settings (or as least some of them) seem to be changed depending on whether driver memory 1 or driver memory 2 are selected. I need to re-review the owners manual to get to the bottom of this.
Are you referring to the Bass Mid Treble adjustments, or the DSP adjustment presets?
caddysrx05
11-18-09, 09:10 PM
Yes I'm referring to the Bass, Middle, Treble etc...
