ShaneH85
11-06-09, 10:36 AM
Where and what is the pattern of the screws that hold the mass air sensor in place??!?!? AHHGG!! I can not for the life of me find anything to fit it and i need to clean it out
| View Full Version : Star pattern screw on mass air ShaneH85 11-06-09, 10:36 AM Where and what is the pattern of the screws that hold the mass air sensor in place??!?!? AHHGG!! I can not for the life of me find anything to fit it and i need to clean it out V-Eight 11-06-09, 10:39 AM I'm assuming its a torx screw. ShaneH85 11-06-09, 10:44 AM No its five sided with a needle in the middle. Kind of like a security bit, problem is it is 5 sided, i had a guy look at it and he said it was a special order penta-drive or pentagon over the top bit... Kingoftypos 11-06-09, 10:55 AM Security torx h2oman 11-06-09, 01:25 PM Not sure about the special order thing... Mine came in a small tool kit I bought from autozone for around $10. Not sure on the exact size but I'll take a look at it later today JimmyH 11-06-09, 02:58 PM Security torx I believe they are referred to as "tamper-resistant" screws. Spyke 11-06-09, 03:51 PM I use pliers to unscrew them since they are not that tight JimmyH 11-06-09, 03:57 PM or with some finesse, you can drill down the center pin chevyhighperformance 11-06-09, 04:25 PM I used a dremel tool with a cut off wheel to cut a slice in the head, and I use a regular screwdriver to remove them. JimmyH 11-06-09, 04:33 PM now that's using your head (sorry for the pun) ShaneH85 11-06-09, 04:36 PM why in the hell i didnt think of using a dremel! ill try that tonight, by the way guys i found out what it is, it a t-10 5 point torx hollow point security screw... translation PAIN IN THE ASS JimmyH 11-06-09, 04:51 PM I have one of those wrenches in my garage. I bought it years ago to secure the headlights on my Maxima when people were stealing Maxima headlights for the xenons. ewill3rd 11-07-09, 08:35 PM It should be a "tamper proof torx". Pretty much a regular torx with a pin in the middle. You can buy a set of tools to take them out. I have some bits at work. 3600cc 11-08-09, 11:15 PM I got mine off (and on) with a vise-grip. If your patient and gentle this works. z06bigbird 11-10-09, 12:05 PM I had an uncle who made a whole bunch of special tools back in the 40s and 50s, including a growler to fix armatures. If he didn't have a tool, he simply made it. No formal education, but this guy re-built wrecked Cessna 120s and 140s. He would convert the fabric covered wings to aluminum. Guy franky was a genius, and he had a Harley dealership. Developed many 'fixes' for Harleys back then. Glad to see that many of us have the ambition and drive to make our own tools. There are no problems, just solutions, as Confucius once say. | |
