View Full Version : Need data for 2003 STS heated seat repair
johngmorrison1945
11-05-09, 05:37 PM
Drivers side heated seat function not working. Fuse is good.
iowasevillests
11-13-09, 03:58 PM
Most likely its the heater element in the seat. Use the search feature its been documented many times, but the quick and dirty is that the wire breaks, opening the circuit. Pull the seat cushion out, pull the leather off and you should see a burn mark in the seat padding, dig around a bit and you should find 2 small gauge wires with burnt ends....there is your problem. You can either cut the ends back and solder back together or replace the entire element, you can find the element on gmpartsdirect.com I believe.
Mark C
11-13-09, 04:25 PM
Heres all the part numbers for 98 and up Sevilles;
The part number for 2002 and newer seat bottom replacement "kits" are
25755075-Front Seat Back Heater Pkg-LH/RH
25755078-Front Seat Cushion Heater Pkg-LH/RH
All of the parts are :
1st Design - For 1998 - 2000 Vehicles Built BEFORE VIN YU204670
Part Number Description
25755073 Heater Pkg-F/Seat Back Cushion-LH
25762972 Heater Pkg-F/Seat Back Cushion-RH
25755076 Heater Pkg-F/Seat Cushion-LH/RH
25755082 Heater Pkg-R/Seat Back Cushion-LH
25762973 Heater Pkg-R/Seat Back Cushion-RH
25755085 Heater Pkg-R/Seat Cushion-LH
25762974 Heater Pkg-R/Seat Cushion-RH
2nd Design - For 2000 Vehicles Built AFTER VIN YU204669 to 2001 Vehicles Built BEFORE VIN 1U228114
25755074 Heater Pkg-F/Seat Back Cushion-LH/RH
25755077 Heater Pkg-F/Seat Cushion-LH/RH
25755083 Heater Pkg-R/Seat Back Cushion-LH/RH
25755086 Heater Pkg-R/Seat Cushion-LH
25762975 Heater Pkg-R/Seat Cushion-RH
3rd Design - For 2001 Vehicles Built AFTER VIN 1U228113 thru 2004 MY
25755075 Heater Pkg-F/Seat Back Cushion-LH/RH
25755078 Heater Pkg-F/Seat Cushion-LH/RH
25755084 Heater Pkg-R/Seat Back Cushion-LH/RH
25755087 Heater Pkg-R/Seat Cushion-LH/RH
submariner409
11-13-09, 04:32 PM
johng, Turn the key ON. Press the seat heater button in HIGH. Listen down at the lower front opening under the seat. Do you hear a tick every 4 - 10 seconds ?? If so, heater wire burned.
Use Mark C's info and either take it to a dealer or remove the seat and DIY. Takes some doing, but needs a few magic words and socket wrench work. The seat pad kits are dealer only as posted at www.gmpartsdirect.com, www.gmotors.com, or call Luke in Parts at Lindsay Cadillac over there >>>>> M-F 9-5 EST.
chubbyranger
11-13-09, 11:28 PM
www.turbojimmy.com There's a great how-to on heated seat element repair.
Ranger
11-13-09, 11:32 PM
Have you checked the Tech Tips section?
That link doesn't work Chubby.
chubbyranger
11-14-09, 06:32 AM
Looks like his site got taken down:
The website you are looking for, turbojimmy.4t.com, has been disabled due to billing issue.
Bummer, he had some good stuff there. I think there are some other threads with pictures here but I lost my bookmark library.
FTT843
11-18-09, 06:20 AM
My parts guy at king gave me the gm repair guide when i bought my new elements. Ill see if i dont still have mine to scan onto the comp, it not just run over to a dealership and grap a copy.
