GordonM
08-03-04, 04:31 PM
I own an 04 SRX AWD, 4.6 V8, Ultraview, silver smoke, nuetral interior, luxury utility pkg, 3rd row, wood kit, chrome wheels, 235 60 18 tires all around.
I have been patiently waiting for aftermarket performance accessories for the SRX for almost a year. But nobody seems to carry a selection of products. From what I have heard there should be some things showing up at SEMA this year.
I made a couple of mods to my SRX that made a big difference and showed how air starved the stock air intake system is on the 4.6.
I purchased a K&N filter charger #33-2059 5.875" x 10" panel filter, cut out an 1/8" PVC plate the size and shape of the existing stock filter so it would fit the airbox, then slit the rubber side wall of the K&N filter and trimmed a small V section out of one corner so the filter would fit in the airbox, and reglued the side wall to the filter using Permatex black hi temp silicone after carefully degreasing the black rubber parts of the filter. Then I glued the K&N filter into the PVC plate using Permatex silicone, added 1/8" x 3/8" foam gaskets on each side of the plate, let it sit over night and installed it in the airbox after trimming off one of the air box baffles.
The air box gets it's air from an area between the headlight and turn signal, with no access to air from the grill or bumper external openings, except from a small hole in the splash pan below the bumper. I opened up this hole to 2 1/2" diameter.
I was pretty amazed at the low end punch improvement, and general performance increase, just from these mods.
Now all I need are bigger brakes, Corsa exhaust, and 400 hp.
I really love my SRX, it is a great ride. Although an SRX V with a six speed manual would be nice.
Gordon
Gordon
