View Full Version : As the cold weather does, so does the hesitation V-Eight 11-04-09, 11:23 PM Ok, so it hasn't stalled yet, but I'm sure that it will at some point when it gets colder. The car will bog from a stop when its cold, once you're going, there are no issues. It will also be fine after about 15 min of driving (no more bog). No codes, any idea what this could be? submariner409 11-05-09, 10:04 AM 4.9 pushrod engine, throttlebody injection, right ?? (Update your profile.....)
Sounds like the cold weather enrichment signal (the electronic "choke") is incorrect. Does your car have an ambient air temperature sensor somewhere near the front of the radiator and is it functioning?
..............maybe the intake air charge temp sensor....... V-Eight 11-05-09, 12:07 PM 4.9 pushrod engine, throttlebody injection, right ?? (Update your profile.....)
[I].
Yes. Does that mean that its running to lean when its cold, then its at the right a/f when its warmed up? Not sure to the last question.... Wait a minute. Isn't the 4.9 multiport injected? V-Eight 11-05-09, 12:27 PM Whoops, just read pushrod. Yeah, its MPI. submariner409 11-05-09, 03:51 PM Either way, injector timing is changed to supply a richer mixture at cold starts and during the first phase of warmup. That enrichment function is controlled by the various temp sensors and MAF input to the ECM/PCM. V-Eight 11-05-09, 07:34 PM Yeah, I meant mine must be running lean, and then when the engine is warm it can run that leaner mixture w/o a problem but for the first little while it hesitates. So how many different sensors are there? submariner409 11-05-09, 07:42 PM For starters, the IAT (Intake Air Temp), the coolant temp, and maybe the ambient air temp is tied in there. One, two, or all three can combine to set fuel ratios along with the MAF. ral1960 11-08-09, 03:17 PM My 04 Deville would run like it was congested for the first mile or two in cold weather. Turned out it was the parking brake not releasing fully. V-Eight 11-10-09, 12:59 PM My 04 Deville would run like it was congested for the first mile or two in cold weather. Turned out it was the parking brake not releasing fully.
I know that my auto release is messed up, but I never set the parking brake, so it couldn't be that V-Eight 11-10-09, 02:29 PM Had that checked. submariner409 11-10-09, 03:01 PM Is your parking brake release vacuum operated? If it is, and you have a vacuum leak in that system (not uncommon), then that's a distinct contributor to your hesitation. Yes, his brake release is vacuum operated. Probably a bad diaphragm. mrtalkradio 11-10-09, 06:09 PM Ok, so it hasn't stalled yet, but I'm sure that it will at some point when it gets colder. The car will bog from a stop when its cold, once you're going, there are no issues. It will also be fine after about 15 min of driving (no more bog). No codes, any idea what this could be?
I hope this isn't silly or insulting in anyway. I am no where as technical as these others are, but my 92 Brougham starting doing that bog thing late sept early oct. I changed plugs, wires distrbtr/rotor. No more bogging. Just a thought and all I can contribute. V-Eight 11-10-09, 08:26 PM Is your parking brake release vacuum operated? If it is, and you have a vacuum leak in that system (not uncommon), then that's a distinct contributor to your hesitation.
But it would only affect the vehicle when its cold?
No worries, any input is welcome. But the distributor was just changed as well. Originally Posted by submariner409 View Post
No.. V-Eight 11-11-09, 03:10 AM So its most likely running lean and I should check into the other things first? Check for a vacuum leak at the brake release diaphragm. | |
