poor-sha
11-02-09, 06:07 PM
Has anyone contacted Cadillac yet to see if there is an updated firmware TSB for the nav unit? I'm sorry to nit pick but when you buy a nav unit with an option to auto update the clock from the GPS and to update for DST but does not it's a bit annoying to have to turn those options off to get the correct time.
What also concerns me is that this means the underlying CE OS wasn't patched from ~3 years ago when they implemented this changed in DST schedule. I sure hope there aren't any other patches missing.
CTS-V-TWIN
11-02-09, 07:17 PM
Where is the digital clock on the Nav screen?
I don't see it. I have been using only the analog clock.
SG
poor-sha
11-02-09, 08:05 PM
It's on the config menu. However, I first noticed the problem when my GPS showed me with an ETA of an hour late for my meeting.
What do you really expect with a Micro$oft operating system in a car ?
tedcmiller
11-03-09, 12:08 AM
First, there is no time display on the GPS or radio. Secondly, there is no TSB or new software. All Cadillacs have operated this way ever since day one. The GPS will use the current time from the satellite as requested, but the user has to turn off (or on) the DST setting. This is done by use of the Config button on the center console. You will not be given the option of displaying the time on the radio or the GPS on the 2009 CTS-V. Setting the analog clock also requires operator intervention. Neither the digital clock (which cannot be displayed on the GPS or the radio) nor the analog clock are updated for DTS changes automatically. Micosoft has nothing to do with it.
mpouls1
11-03-09, 12:36 AM
I don't know if this helps but I was perusing the technical bulletins awhile back and remember seeing this. I don't know what timeshift operation is but it may be what you are talking about.
#08-08-44-019D: Intermittent XM, Blank Display, System Resets, Timeshift Operation or Music Copy Functionality, Incorrect Dimming Level, System Stating Unable to Plan Route After Route Deviation, Radio Locks Up After - (Sep 15, 2009)
Subject: Intermittent XM, Blank Display, System Resets, Timeshift Operation or Music Copy Functionality, Incorrect Dimming Level, System Stating Unable to Plan Route After Route Deviation, Radio Locks Up After Destination Download, System Intermittently Not Showing Low Fuel Warning (Update Navigation Radio Software)
Models: 2008-2009 Cadillac CTS, CTS-V
Built Prior to VIN Breakpoint 90165754
Built Prior to 03/25/2009
Equipped With Navigation Radio (RPO UAV)
Condition
Some customers may comment on any of the following concerns:
• Intermittent XM operation.
• Intermittent timeshift operation.
• Intermittent music copy functionality.
• Intermittent blank display (no text, intermittent touch control).
• Incorrect dimming level (night dimming during day or day dimming at night).
• System stating it is unable to plan a route after a route deviation.
• System intermittently resets (shows Cadillac startup animation).
• System intermittently not showing Low Fuel warning.
• Radio locks up after OnStar® Destination Download (ODD) usage.
• Radio that was turned OFF on the previous ignition cycle may turn ON.
• Date configuration screen displays MM/DD/YYY when DD/MM/YYY is selected.
• Clock configuration displays "Année" for the year.
• Weather information display is slow.
• An Emergency Broadcast System alert may cause a system reset condition.
• Traffic information doesn't include highway entrance/exit.
• Traffic announcement is incorrect.
• Traffic announcement is given while radio is OFF.
• Point of Interest (POI) list only displays Thai restaurants.
• System displays Florida's nearby POI when user selects Nearby POI. Screen displays 3D sky and ground.
• Voice guidance is given at the beginning and arrival when voice guidance is selected OFF.
• Time shift key doesn't work.
• Time shift buffer increases while XM has no signal.
• Screen transits to power OFF after audio SW update.
• Audio hardkey (HK) press is not available while user is pressing "+: holding HVAC HK.
I don't know why, but I like to occasionally look up what types of problems customers are having with their cars :)
brianwetzel
11-03-09, 01:08 AM
The Timeshift operation is the hard drive copying up to one hour of radio. The supplied answer of manually setting the DST is correct.
mpouls1
11-03-09, 01:37 AM
Ah, gotcha. Well at least we know what to do if the above happens.:cheers:
CTS-V-TWIN
11-03-09, 01:47 AM
My V automatically changed the time one hour back. I didn't have to do anything. It seemed to automatically link up to the GPS Satellite on it's own and when I got in the car, the time had already been set to the correct time. Of couse, I had to manually set the analog clock.
SG
tedcmiller
11-03-09, 03:41 PM
Your CTS-V did not change the time automatically. As I said before, this does not happen automatically. In all likelyhood you never changed the time from no DST, since you can't see it on the radio or the GPS. As a result you did not know the digital time was off by an hour during the DST period. You just think it changed the time back when, in reality, nothing happened.
