LuvTopless
11-01-09, 03:16 PM
This is my first time posting (brand new member - looking to pick some brains on an issue) I know there have been a lot of threads about starting problems either caused by a dead battery, bad ecu or cps. This issue doesn't seem to fit exactly as other threads I have read so I wanted to get some input from people that might know the answer.
Background:
2003 CTS, 3.2L v6, ~80,000 miles, no warr.
Symptoms:
Two keys/key fobs for the car, started the car the other day with the first key and got a message on the DIC (driver information center), saying "check theft deterrent system". The car would start, but would not shift into gear. Tried the other key and the car started up and ran fine. Figured the chip in the first key may have been damaged from being in my pocket or something.
A few days later, was out in the morning running some errands, everything was fine. That afternoon, went to go out, got the "check theft deterrent system" message again. Shut the car off, tried to restart it, when I turned the car on the DIC came on, as did the climate control display, and all the warning lights, as usual, they then went blank and the car would not start. The check engine light stayed on but blinked on and off randomly and the car locked the key in the ignition. From outside the car you could hear a relay or something under the hood clicking on and off, seemingly randomly, disconnected the battery so it would not run down. No warning lights or anything on just that theft message with the first keys and then with the second. The car ran fine the last time I drove it before this.
I know sometimes its a bad cps but from what I have read you can usually turn the car over, it just wont start.
I have read some threads where people have had the issue while driving (I didn't but could have been just a timing issue).
I am not sure what the clicking would be under the hood, and I don't recall reading any threads that mentioned that (could have just not heard it).
I am leaning towards a bad ECU but before I start dishing out a few hundred $$$ I would like to see if anyone else has some ideas or suggestions.
Thanks for the help!
Background:
Symptoms:
