wamanning
11-01-09, 12:30 PM
my turn signal relay is going bad.
any idea what teh official GM part number is? i pulled the part and here are the numbers i see:
09 225 528
54 204 003
PA6.6-GF30
i searched gmpartsdirect for any of these numbers and got nothing.
i googled and the only thing that came back was teh last one, and it's a relay for vw/audi, which makes sense. that said, i cannot locate the equivalent gm part number.
ideally, id like to replace this with a solid-state load-independent relay...in which case i still need teh OEM part#. i also tried to match based on the pin configuration, but none i can find have the same # combination next to the pins.
i'd appreciate any help!
also, here's the pin configuration:
| E
| 49 | 31
— 49a
E/31 = GROUND
49 = BATTERY
49a = LOAD
09 225 528
54 204 003
PA6.6-GF30
| E
| 49 | 31
— 49a
E/31 = GROUND
49 = BATTERY
49a = LOAD
