dzlfumes
10-31-09, 02:02 PM
Only 12,486 miles on my 06 DTS and I have a front crank seal leak!! What gives? It is being covered under warranty, but is there anything else that should be looked at or into? TIA for any help.
| View Full Version : 06 DTS crank seal leaking dzlfumes 10-31-09, 02:02 PM Only 12,486 miles on my 06 DTS and I have a front crank seal leak!! What gives? It is being covered under warranty, but is there anything else that should be looked at or into? TIA for any help. submariner409 10-31-09, 03:25 PM A front crank seal failure is so rare that this has to fall into the "infant mortality" category. dzlfumes 11-01-09, 08:58 AM Yeah, as you can notice from the mileage the car has not been driven very much at all and it actually has been sitting for a while. With that said I was wondering if it could be attributed to the lack of lubrication to that seal causing it to fail. submariner409 11-01-09, 09:41 AM I seriously doubt that is the case: new and rebuilt engines and transmissions sit in warehouses for months, even years, and have no problems on startup. Ask the repair tech to take a hard look at the seal before he pops it out of the block groove - either a collapsed/broken spring or a cracked lip. dzlfumes 11-01-09, 10:03 AM Thanks, will do! | |
