jim mancuso
10-31-09, 12:59 PM
I purchased a 2009 automatic and have approximately 200 miles on it. I have a pulley chirp when the car is first started in the morning, which will last about one minute. Then it turns into a soft squeal, which will last about 5 minutes. On other starts during the day it does not happen. I took it back to the dealer and after 3 days they said there was nothing wrong with the car, that the sound was coming from the exhaust manifold. I know this is not correct. Has anyone else had this problem.
SlvrBullIT
10-31-09, 04:26 PM
In my experience the high pitch squeal is typically belt slippage, belt conditioner or dish soap can help. Dealership should fix that permanently.
GMX322V S/C
10-31-09, 04:58 PM
I purchased a 2009 automatic and have approximately 200 miles on it. I have a pulley chirp when the car is first started in the morning, which will last about one minute. Then it turns into a soft squeal, which will last about 5 minutes. On other starts during the day it does not happen. I took it back to the dealer and after 3 days they said there was nothing wrong with the car, that the sound was coming from the exhaust manifold. I know this is not correct. Has anyone else had this problem.No, and this sounds bogus and lazy of your dealer's service department--you may want to discretely escalate to the service manager, but if he blows you off, you may want to send a polite letter to your GM regional office, copy the SM and find a new dealer if possible. Besides what Slvr suggests, it could also be an idler pulley bearing going out.
SlvrBullIT
10-31-09, 05:16 PM
True, without hearing we can speculate all day long.
