View Full Version : 67sdv door panels/interior q's
67badazillac
10-28-09, 09:45 PM
how do i take these off i only see a couple scres around the interior door handle and i dont wana just rip it off if theres any other hidden ones. is there just a bunch of clips?
also, where were the stock speakers located?, i found two, what looks like 6 by 9s in the back, , nothing on the doors, my radio doesnt work but when i try to turn it on i thnk i hear static coming from the dash, is there a speaker in there too?
another thing is on my dash , almost right behind the top of the steering wheel, i have this cutout which had a plastic vent on it that snapped off, it doesnt seem to be connected to any a/c,heating system because i dont see a hole, just this strange metal wire. is it for a litght or something? its my cellphone holder now :D
and one more question, know where i can find any shop manuals for my car? that might help me in simple things and specs about my 67?
raysteen
10-28-09, 11:47 PM
Can't help with the door panel much, but if there is a light in it, check behind the lens.
I am sure there is a speaker in the dash, possibly two if the 67 had a stereo radio. My '69 (long since gone) didn't have speakers in the doors, just the dash and rear panel.
The plastic vents on the front of the dash to the rear of the steeringwheel cover the sensor for the automatic climate control.
Try eBay for the factory manual.....wait long enough and one will turn up.
77CDV
10-29-09, 12:02 AM
There are screws around the perimeter of the door panels. They go in quite far so as to be mostly hidden from view. There are also clips on the rear of the panel that snap into corresponding holes in the doors. So, search out and remove all the screws, including any ashtray/window controls from the armrests, then you can very carefully use a flathead screwdriver to pry the panel away from the door. Start at the bottom and work toward the top. The top of the trim panel should just slip over the top of the inner door panel. Don't forget to remove your door lock trim buttons, too.
1967 cars either have two speakers, one in the rear parcel shelf and one in the middle of the dash top, or if equiped with stereo, two in the rear parcel shelf and one at either end of the dash top. There are no speakers in the doors or kick panels.
As raysteen noted, the vent over the steering wheel houses the interior temperature sensor for the climate control.
