View Full Version : struts and shock help
mywifekids1
10-27-09, 06:47 PM
Need help looking for front and rear struts and shocks for my 05 STS my problem is I can't find them for sts with magnetic ride control does anyone know where to buy them other than Gm the dealer wants 1400.00 just to change the front.A part number for the front and rear would be good also.
EChas3
10-28-09, 11:59 PM
Are you sure you have Magnaride? It's gonna be big bucks. If your heart is set on new, you're going to need one of the discounters like GMPartsDirect. A little search engine work should get you the stuff.
If the shocks aren't leaking, they may not all be bad. Is it possible to make the car bounce more that once + rebound? you could get by with used from a recycler.
Bushings and other parts shouldn't be outragous money.
mywifekids1
10-29-09, 10:04 PM
The fronts are leaking and the rear when you squeeze the foam part it stays constricted so those are bad as well i'm looking all over even used I don't drive it except weekends so I have time to find a good deal.
