View Full Version : I cant find my steering column tilt lever...
DrFunky
10-27-09, 04:24 PM
I needs help...
DrFunky
10-27-09, 04:25 PM
(its a 67 deville)
Stingroo
10-27-09, 04:40 PM
I may be wrong, but that generally means you don't have tilt steering. :p
DrFunky
10-27-09, 04:59 PM
good point
Stingroo
10-27-09, 06:53 PM
It is really strange not having it though, so I can see the reason for your question. I like having it, because I have long-ish legs and otherwise it's a royal pain in the arse getting in and out of some cars.
sven914
10-27-09, 09:49 PM
Just push on it really hard... It'll tilt.
The tilt-telescopic steering wheel was a $90 option for 67. It shouldn't be too hard to change it for one with tilt. See motorera.com (http://www.motorera.com/cadillac/cad1960/CAD67D.HTM) for more information about your car's options.
DrFunky
10-27-09, 10:04 PM
Exactly. lol Im 6 foot 3 inches tall.
DrFunky
10-27-09, 10:06 PM
thanks!
77CDV
10-28-09, 06:50 PM
You don't have a tilt steering column. You would have to swap one in from a donor car.
DrFunky
10-29-09, 01:36 PM
cool...
Slacker
10-29-09, 04:25 PM
My '84 Chevy doesn't have tilt steering either. I found it odd that it didn't but getting used to it wasn't too bad. (I'm 6' tall)
DrFunky
10-31-09, 10:36 PM
And there's no turn signal
sven914
11-01-09, 01:09 PM
Then whats that leaver coming off the left side of the column?
http://www.cadillacforums.com/forums/attachments/rwd-19xx-1984-deville-fleetwood-1985/53412d1256671481t-i-cant-find-my-steering-column-102709150740.jpeg
Stingroo
11-01-09, 02:01 PM
^ I was kind of thinking that too.
77CDV
11-02-09, 12:57 AM
Unless his directional signal flasher is burned out.
75sled
11-02-09, 01:18 PM
I don't know if Cadillac is this way, but some of the old Chevy trucks (late 60s) had tilt steering that you would operate by actually pushing the turn signal lever toward the dash. You might see if it works here.
Stingroo
11-02-09, 01:52 PM
Now that I've never heard of. Interesting note.
outsider
11-02-09, 02:47 PM
yeah never heard of that either...sounds like a cool idea though :D
SilkyBrown
11-02-09, 03:24 PM
I had the same problem on my 70' No tilt!!!! I had to buy a Tilt Column off another 70' on ebay. Turns out not all Deville's came factory with the tilt & teloscopic functions. at 6'3 i definately needed the tilt. Not to mention i swapped out my old seats for new Caddy Buckets but thats a whole different topic! lol
77CDV
11-04-09, 03:45 AM
Won't work on a Cadillac. Tilt function was always a separate lever.
DrFunky
11-05-09, 03:42 PM
Thats apparantly the turn signal. I couldnt see what it really did til a few nights ago. You mean to tell me I have to manually blink my turn signals?? lol
DrFunky
11-05-09, 03:44 PM
my instrument panel is burned out, and it doesnt hold in one position and blink like the new cars do. When I push down and up it activates the lights in my front quarter panels but I have to do it manually to give the appearance of a blinking turn signal...
DrFunky
11-05-09, 03:46 PM
correct, theres no tilt, looks like I may either have to deal with it or swap it out. Cant do anything right now though.
77CDV
11-07-09, 04:50 PM
The lights I think you're refering to in your front quarter panels (they're white and bright, yes?) are the cornering lights. They're supposed to come on and stay on steady when you activate the turn signal with the lights on. On the top of each front fender is an indicator light that should flash in unison with the turn signals (unless the bulbs within them are burned out).
Try this. Flip the directional on, get out of the car, and look at the front and rear turn signals. If they're bright but not flashing, you either have one or more bulbs burnt out, or your turn signal flasher is dead (esp. if you get no flashing from both sides). Both are cheap and easy fixes.
DrFunky
11-11-09, 01:47 AM
thanks for the advice!! :thumbsup:
However my turn signal lever does not stay in one position... it keeps moving back to the center position every time I let it go...
77CDV
11-11-09, 02:45 AM
But, do the turn signals flash normally when you hold the lever in position? If yes, then all you need is to replace the detent spring or the signal switch. But, since you're swapping out your steering column for a tilt/telescope model, it's a moot point.
DrFunky
11-11-09, 01:49 PM
When I hold the lever in position the light does not blink. It just stays illuminated constantly.
And I havent even gotten CLOSE to switching out the steering column yet, Im still playing with ideas....
77CDV
11-11-09, 06:42 PM
OK, then check all your bulbs for burn outs. If all the bulbs are OK, then replace the flasher. It's located under the dash, on the lower dash cover next to the steering column. Readily available at any auto parts store for cheap.
DrFunky
11-11-09, 11:58 PM
thanks! :cool:
