View Full Version : 95FWB running hotter after coolant change.
HUF
10-26-09, 08:28 PM
I have changed coolant in my 5.7 l by disconnecting the lower radiator hose. Put a tube of Bars Leaks Golden Powder into the hose. Added about two gallons of 50% green coolant to the reservoir.
Unfortunately, I did not open that bleed valve next to the thermostat. Probably because of air pockets the coolant started boiling after the engine ran for a few minutes.
I turned it off and to took the car for a short ride. The coolant temperature was not around 174F as usual, but rather in 180 -185 range. Added a little bit more coolant the next morning. Drove the car for four hours (a business trip) - still the same 180 -185 F. STRANGE! What happened to the cooling system?
By the way, the lower radiator hose is much cooler then the upper one. I could not detect sharp temperature drop as the thermostat opened up as it's been on my 4.9 liter 1991 Seville.
Any comments are appreciated!
I~LUV~Caddys8792
10-26-09, 08:47 PM
For some odd reason, when I did the coolant flush on the S Class I had, it ran a bit warmer as well. Nothing abnormal, but it was about 15-20* warmer than usual.
HUF
10-26-09, 09:02 PM
15-20 degrees F seems to be a big difference. Mine's about 10 degrees and makes me nervous! One of my theories is that because the coolant boiled , the thermostat got affected and opens at higher temperatures. The other theory is related to the coolant supplement I have added. There was not any supplement in the coolant I have replaced, despite the FSM says it is a must.
jayoldschool
10-26-09, 10:13 PM
You need to bleed the air out using the bleeder on the thermostat housing and check it again.
HUF
10-26-09, 10:31 PM
Thanks, Jay. I will do that tomorrow and will report back. Another weired thing (is not it too much? lol). It took only 4 qtrs of motor oil with filter change instead of 5 qtrs. Checked the level two times when engine was cold and all three holes on the deepstick were covered. I used Penzoil 10W-30. I do not know whether it was a good choice though (some suggest only 5w-30).
HUF
10-27-09, 04:38 PM
Opened the air bleed screw. There was no air whatsoever, only coolant.
jayoldschool
10-27-09, 09:41 PM
This was after the car was warmed up with the thermostat opened? Might help to get the nose of the car up in the air.
HUF
10-27-09, 09:46 PM
That's what I wanted to do, but because of rain I checked it with cold engine. I do not think there may still be air in the system after 500 miles and several heating-cooling cycles, but I might be wrong since I am not familiar with pressurized cooling systems at all.
jayoldschool
10-27-09, 10:37 PM
Have to check it hot.
HUF
10-27-09, 11:29 PM
Is Penzoil a good brand? Never used one before.
