superoli
10-25-09, 03:02 PM
Hi everybody,
during summer my blower stopped working especially during hot days, but then came back after a couple of hours.
Since last week it stopped completly. AC and heating are still working.
I would like to check the blower, but I do not now where the blower is located.
Maybe somebody even has a repair manual for it.
I am lookin forward for every hint, since I really do not want to drive through winter witout a blower.
Thanks in advance...
pjbizjak
10-25-09, 08:43 PM
On a long shot, check for blown fuse.
superoli
10-25-09, 08:50 PM
Fuses are okay. I checked them...
The blower is on the right side (passenger side) behind the glove box. The Service Manual says to remove the closeout /insulator panel first, then the instrument panel compartment (glovebox). That you give you access to the blower motor (for inspection or removal).
The above information is for a '06 STS. (I would assume this to be accurate for all current generation STS's)
Be careful testing. I think all GM blowers are now driven by solidstate output of varying voltage (not like the old days at all).
superoli
11-01-09, 01:42 PM
Today, I made my way to the blower and I suppose I found the problem.
The "HVAC Control Processor" is nor working correctly.
I can see different voltage coming in on Pin 2, depending on what speed I choose at the blower switch.
But there is 0 volt an the two cables, connected to the blower.
Furthermore I connected 12V to the blower and it started instantly.
So I would order a new "HVAC Control Processor" unless one of you would tell me, that I missed something here.
Any help is appreciated....
superoli
11-01-09, 03:39 PM
Update:
I took another look at the Schematics for the Blower Controller.
At my tests I had no power on Pin 3 and Pin 4. (see atachement)
If I have no power on Pin3 than rather the fuse or the Relay is malfunctioning.
But. Fuse and Relay are okay. I checked them both a couple of times.
Leaves only the wiring! Or does anybody have another idea ??
How did you make out with this?
z06bigbird
11-10-09, 12:41 PM
As one member said, today's blowers are very complicated looking things. No longer just a cheap fan. My service mgr has one sitting on his desk. A real eye catcher, and it retails for about $400 as I recall. (I want my 91 Cutlass back--seems like nothing on that car cost more than 10 cents.) lol
Looks to me like a dealer visit is in store for you.
mywifekids1
11-10-09, 06:19 PM
Off topic just a little The rear shocks for this car are 483.00 apiece the front struts are 430.00 apiece so i feel your pain about going to the dealer for your blower 05 sts 1sg.
