View Full Version : Symptoms of faulty distributor pick up coil
mike93
10-24-09, 07:55 PM
What are the symptoms of a faulty distributor pick up coil?
Sevillian273
10-24-09, 10:12 PM
No spark. The coil's resistance should be between 500 and 1500 ohms
mike93
10-24-09, 11:04 PM
well i think thats why my car stutters on acceleration because no spark to the spark plugs i have a feeling thats what it is it runs like it's not getting spark
Sevillian273
10-25-09, 08:59 AM
If the coil was bad it would not run at all. If its not throwing codes, then it sounds like a fuel injector issue. Youll have to check their resistance with a digital volt meter. They should be between 12 and 18 ohms each.
Dave S Texas
10-25-09, 12:17 PM
Mike.....a man that does his own work should have the Cadillac Factory Service Manual to take the guess-work out of the equation. Plenty available on ebay for $20/up. Best tool a Cadillac DIY'er can own. Smart spend.
mike93
10-25-09, 08:13 PM
ok ill buy one because i do do a lot of my own work
Dave S Texas
10-25-09, 09:31 PM
Good man! Go to ebay site and type in 1993 Cadillac Service Manual>click Search>shop/purchase
mike93
10-25-09, 09:52 PM
ok thanks and why do you think could be wrong with my car because i read a post on here that were having the same symptoms as i was and i was the distributor pick up coil
Sevillian273
10-25-09, 09:59 PM
You have to check the coil to know for sure. You NEED a digital voltmeter. You can get one for around $20
mike93
10-25-09, 10:12 PM
ok thanks
ewill3rd
10-26-09, 09:34 AM
A failed pickup will cause the engine not to run.
Checking a coil with an ohmmeter will rarely give you an indication as to whether or not it is really bad unless the car is already just not running.
Usually the issue is the magnet cracks on the shaft, this creates magnetic poles that are not supposed to be there and it can cause drivability issues.
If it has been forever, I would overhaul the distributor using Delco parts and replace the mainshaft which comes with a new magnet, and the pickup coil for sure.
Be sure you properly follow the timing procedure.
