View Full Version : Tire Pressure Monitoring System
Punmax
10-23-09, 11:20 PM
So guys, I took the 18's off for about 5 months, and I just put them back on. The system was working when I took the wheels off, but now nothing comes up. Any ideas?
3DRacing
10-24-09, 02:53 AM
Try the tire pressure sensor relearn procedures. There is a sticky note created for this process at the link below. I believe there are different steps depending on your year/model.
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-2007/127467-2007-up-tire-pressure-sensor-relearn.html
Punmax
10-24-09, 10:43 PM
Truck was sitting for two days in the garage. Went to start it up, and it displayed the pressure for all 4 tires. Woohoo!
3DRacing
10-25-09, 06:40 AM
Now the question is whether you installed the tire and wheels in the exact same position as when they were removed 5 months ago. If not then you will get the wrong tire pressure reading from the wrong tire and wheel. The relearn process lets the vehicle identify where each sensor is located on the vehicle. You also have to perform the the relearn process after you rotate your tires.
hcvone
10-26-09, 10:57 AM
It does not matter if you put them back in the same location, if your other wheels had sensors then the new wheel sensors have to be reprogrammed. :)
Caliber
10-28-09, 12:07 PM
I think we should Make a Sticky on The Tire presure monitor. so when people change there tires from summer and winter they don't have to run to the dealer and pay them when it can be done yourself. unless of course you have an 09 and 10 and have to take it to the dealer
hcvone
10-28-09, 12:44 PM
I did that in 2007, just look under the sticky up top, here is the link
Banned
11-04-09, 04:58 PM
where is the cheapest place to buy these sensors?
hcvone
11-05-09, 09:08 AM
E-Bay you can find them dirt cheap from time to time, I have purchased many off E-Bay
